wall boundary conditions
Old   August 21, 2008, 00:48
Default wall boundary conditions
sivaramakrishnaiah
hi what is meant by rotating wall,how to give in CFX-11
Old   August 21, 2008, 11:14
Default Re: wall boundary conditions
MAB
the wall would rotate with a sepecified velocity( angular velocity)
Old   August 21, 2008, 11:25
sivaramakrishnaiah
i given in that some error is showing my boundary conditions: inletressure 7.5bar and tem;167C outlet i given mass flow rate:0.3kg/s fluid:steam
ERROR #002100048 has occurred in subroutine SU_BNEXT. | | Message: | | All vertices for a fluid domain lie on boundaries. This is | | considered to be a fatal error because control volume gradients | | cannot be calculated, leading to serious discretization error. | | | | A common cause for this error is a mesh which is only one | | element thick, without symmetry or 1:1 periodicity on the lateral | | boundaries. If you have this situation, and the domain is | | two-dimensional, please change the lateral boundary conditions | | to symmetry or 1:1 periodicity. Alternatively, for | | three-dimensional simulations, please ensure that your mesh | | has at least two elements across. | | | | Execution is terminating. This error message can be bypassed by | | setting the expert parameter 'boundary vertex check = f', but | | be aware that doing so may lead to sigificant solution error. | +--------------------------------------------------------------------+
wall functions and boundary conditions in OF 1.7.1 cristobal OpenFOAM 2 May 6, 2011 05:10
Wall modelling and boundary conditions: why specify value for turbuelnce quantities? djbungee OpenFOAM Programming & Development 2 July 30, 2010 08:32
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
Wall boundary conditions for 3d-cylinder Martin Bellmann FLUENT 1 July 11, 2008 14:04
Boundary conditions? Tom Main CFD Forum 0 November 5, 2002 02:54
