can you have variable density for solid dispersed? |
August 13, 2008, 02:11 |
I am trying to run a 2 phase simulation with air and 2mm solid dispersed particles. In this simulation I am trying to make the density of the solid dispersed phase to be variable i.e. decreases as the y coordinate decreases. I created a new material and in the density I used a formula. The units are correct, however I get this message Fatal bounds error detected --------------------------- Variable: Particles.Density Locale : Default Domain Is it possible to do what I am trying to do? Also with a Eulerian-Eulerian simulation is there any method of imposing a friction coefficient between the solid dispersed phase and a wall? Or can it only be no slip or free slip? Thanks, Tim. |
Variable Density Function | ryzd | FLUENT | 1 | August 25, 2011 15:16 |
error in COMSOL:'ERROR:6164 Duplicate Variable' | bhushas | COMSOL | 1 | May 30, 2008 05:35 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 05:41 |
variable density water | Atit Koonsrisuk | CFX | 2 | July 24, 2003 04:07 |
Replace periodic by inlet-outlet pair | lego | CFX | 3 | November 5, 2002 21:09 |
