Transient Case
Old   August 8, 2008, 08:04
Default Transient Case
MAB
I am getting around 6 million cells and it is a transient case. How long you think CFX will take to complete this simulation. the smallest cell is about 0.005m . any advice about time step. (coz it is crashing on first loop naming it a Fatal Over Flow). any advice please? thanks
Old   August 8, 2008, 08:50
Default Re: Transient Case
Rogerio Fernandes Brito
Did you create any own material? (donīt forget the input the Cp, ro (density), and K).
You might have at least 8 GB of RAM!
Change the turbulence model (and the same for the scheme of convection)
Decrease the time step. (use 0.1 s)
Old   August 11, 2008, 02:17
6M cells in a low Re simulation - easy, quick, but need a bit of memory. 6M cells in a multiphase, transonic, reacting flow with mesh motion - you will need a supercomputer.
Without more detail we cannot help.
Old   August 11, 2008, 07:02
MAB
Hi thanks I think it is low Re , multiphase flow( water waves) ...what do you think about it. do i still need a supercomputer???
Old   August 11, 2008, 19:39
Modelling water waves is tricky and slow on CFX. Again it still depends on many things but you should be able to run on a machine with a good deal of RAM (or better still a cluster). If you are just modelling water waves you will probably find better software which will run much faster.
Old   August 12, 2008, 05:56
MAB
Thanks Glenn, Could you please suggest me anyother sofware for this pupose of modellling water waves. thanks MAB
Old   August 12, 2008, 23:33
We have fluent and CFX and fluent does it much better. There are also myriads of other software for coast and ship design which are worth looking into.
Old   August 13, 2008, 08:52
MAB
does fluent has moving mesh or cut cell capability???
Performance of GGI case in parallel hannes OpenFOAM Running, Solving & CFD 26 August 3, 2011 04:07
Transient case with no inlet region Ancient_Nik CFX 11 March 21, 2011 02:46
Changing the grid on the same set-up Katya FLUENT 7 October 8, 2009 17:31
icoFsiFoam case needed vivekcfd OpenFOAM 1 May 6, 2009 14:41
Transient case running with a super computer microfin FLUENT 0 March 31, 2009 12:20
