CFX/WB mapping
Old   August 7, 2008, 12:14
Default CFX/WB mapping
Karil
Hi, I have done a transient simulation in CFX with two domains and a rotor moving mesh. Now I need to map the pressure results of the rotor into the structural model, but since the rotor model rotates the 'CFX pressure' function in Workbench Simulation doesn't map the right values, except when the rotor and structural model positions match. Is there a way of keeping the rotor's original coordinates while still realising a transient simulation? A frozen rotor approach isn't adequate for my problem. Does someone have experience in this? Thanks!
Karil
Old   August 7, 2008, 12:30
Default Re: CFX/WB mapping
Karil
I forgot to tell, because of the computer cluster this is done in CFX 10.0, and after the CFD simulation is over I work with Workbench 11.0. Thanks
Old   August 8, 2008, 09:28
Karil
Found it, I altered the THETA_SHIFT_REL number value to 0 in the .trn files with a hex editor!
Cht tutorial in 15 braennstroem OpenFOAM Running, Solving & CFD 197 June 10, 2015 04:02
solid to fluid heattransfer with chtMultiRegionFoam nakor OpenFOAM 11 March 21, 2011 09:28
Trimming and Mapping Methods with ES-ICE Zancanaro Siemens 0 June 2, 2009 15:16
MFX mapping question Pat CFX 0 September 12, 2008 09:26
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 09:19
