Thermal Stress by CFX
Old   August 1, 2008, 14:56
Default Thermal Stress by CFX
Riken
Do you if we can determine thermal stresses by ANSYS CFX 10.0 for solid domain?
Old   August 3, 2008, 19:38
Default Re: Thermal Stress by CFX
CFX cannot do this. Need FSI to a FEA software.
Old   August 3, 2008, 21:47
Riken
Can you tell me what is FSI? Is it a module that I have to buy and if yes from whom?
Thanks Riken
Old   August 4, 2008, 06:10
JP
Hi, The best you can do, its to export the temperture field and calculate a Thermal-mechanical in Ansys or another FEA software. You should check if there is need of doing a FSI caculation depending on the degree of coupling of the deformed shape (becouse the thermal strain) and the fluid field.
Best regards.
Old   August 4, 2008, 22:53
FSI - Fluid structure interaction. That is coupling the fluid flow to structural motion. CFX does the fluid flow and ANSYS Mechanical does the structural motion and the different simulation packages are linked to do a FSI simulation.
Old   August 12, 2008, 20:26
Riken
Thanks for response, Please have patient while reading as this may describe my problem better. Well actually I am interested in findiding thermal stress generated in solid domain which is heated by some fluid flow. In order to do this I carried out analysis in CFX and I found temperature profile in the solid, Now the issue is to find thermal stress by this results. I tried to export this results in *.CDB, *.CSV for to load in the ANSYS workbench, but I couldn't do it. Do you have any idea if we can do?
Pros and Cons for CFX, CFdesign, COMSOL Val Main CFD Forum 3 June 10, 2011 03:20
[ICEM] Node Number vs. Node_ID & ICEM vs. CFX Araz ANSYS Meshing & Geometry 1 April 25, 2011 12:03
CFX doesn't continue calculation... mactech001 CFX 6 November 15, 2009 22:25
Reynolds Stress model in CFX vs Fluent Tim CFX 1 October 7, 2009 07:19
Determine Thermal streeses by CFX module Riken CFX 3 August 3, 2008 21:58
