July 31, 2008, 07:56 |
time varying inlet velocity
Hi
I am simulating the time varying inlet velocity profile, which is called buffeting in the bridge, i generate the velocity file, and use the user fortran to read it, here i simulate a square cylinder external flow, but when i watch the drag force, the drag force has negative value, and oscillating up and down, here the bluff body is horizontal to the inlet velocity direction and there is no attack angle, in fact when i did not consider the time varying inlet condition, only the mean velocity value is applied on the inlet, the drag force is the positive, i think the simulation is convergent, so anyone can tell me the reason why the pressure osicillating and negative value happens. |
Problem with assigned inlet velocity profile as a boundary condition | Ozgur_ | FLUENT | 5 | August 25, 2015 05:58 |
Time varying parabolic velocity | fcortes | OpenFOAM Running, Solving & CFD | 2 | September 29, 2010 02:43 |
calculation diverge after continue to run | zhajingjing | OpenFOAM | 0 | April 28, 2010 05:35 |
How to set a time varying velocity field as a BC? | Mikro | OpenFOAM Pre-Processing | 5 | March 19, 2009 05:38 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 10:11 |
