Queueing the simulations
Old   July 29, 2008, 16:51
Default Queueing the simulations
CFDLife
I am running my simulations on Intel dual core processor (windows based). I have parallel licensing.
Is there a way I can queue up a few runs, so that the machine can keep working even when i am away?
Thanks in advance
Old   July 30, 2008, 05:05
Default Re: Queueing the simulations
Toralf
http://www.cfd-online.com/Forum/cfx_...cgi?read=23055
Old   July 31, 2008, 10:36
CFDLife
Thanks, i will try to implement this, will keep u updated.
Old   August 1, 2008, 18:03
CFDLife
I followed exactly how Chirag has described. IT DID NOT WORK.
Can someone throw light on this please
Old   August 4, 2008, 10:33
Toralf
Okay, here is an example.
cfx5solve.exe -def FILENAME.def -start-method "PVM Local Parallel" -part 2 -s 3.3
1. for every file one line 2. put these lines in editor 3. change the file extension from *.txt in *.bat 4. start the batch-file in command line modus in the same directory where you saved the batch-file and where are the def-files 5. you can open the solver monitor window to check the run
p.s. -s 3.3 is memory allocation factor (you can choose other)
Queueing the simulations CFDLife CFX 33 November 6, 2018 12:20
Periodic boundary conditions in 3D Eulerian granular flow simulations dsm FLUENT 4 March 2, 2012 20:04
Hardware selection for steady/unsteady incompressible, turbulent and cht simulations maddalena OpenFOAM 2 July 13, 2011 09:55
Timestepping in two - phase Simulations using RSM challenger85 CFX 0 January 4, 2010 06:00
URANS and Transient Simulations bob Main CFD Forum 0 October 1, 2003 04:54
