Natural convection - Inlet boundary condition |
July 29, 2008, 06:20 |
Hey everybody,
I read many topic about the natural convection and the boundary conditions for the simulation of this phenomenon. I'm studying, with CFX 11, the water flow in natural convection throught a square duct which contains heating source. The duct is vertical. So the inlet is at the bottom and the outlet is at the top of the duct. Althought I have a problem : I put static pressure boundary condition for the outlet ( pstatic = 0) but for the inlet : static or total pressure (pstatic = 0 or ptotal = 0) ?? (I read the two answers on the forum). Could you help me ?? Thanks max91 |
July 29, 2008, 21:28 |
Re: Natural convection - Inlet boundary condition
What is your Reynolds number? I think you have a mixed convection (natural and forced convections) and not only a natutal convection. See my Doctorate Thesis for several comparisons with experimental data (it is not mine) and other numerical data: Go, please to my personal home-page: http://rogeriofernandesbrito.googlepages.com. If u wanna compare with CFX, send me your name.cfx file . I will simulate with pleasure for you! MSN: rogeriobrito2007@hotmail.com, Skype: rogeriofbrito
Table 5.2 â€" Comparison of the results for the square geometry of figure 5.5: Gr = 2.0 Ã- 10^4 e Pr = 0.733 . Reference Nuh Desviation [%] Methd Utilized Ozoe et al. 2.74  Experimental Value Present Work 2.569 - 6.24 Finite Elements (3362 elements) Menon 2.70 - 1.46 Finite Elements (100 elements) Tabarrok et al. 2.695 - 1.64 Finite Elements (200 elements) Wilkes et al. 2.874 - 4.89 Finite Differences (10 x 10) Wilkes et al. 2.516 - 8.18 Finite Differences (20 x 20) Being: Desviation [%] = [( â€" ) / ] 100. Table 5.3 â€" Comparison of the results for the square geometry: Pr = 0.733. Ref. Figueredo et al. Present Work Wong e Raithby Present Work Gr Desviation1 [%] Desviation2 [%] 34 110 2.884 3.023 4.60 2.972 3.023 1.69 60,000 3.468 3.588 3.34    100,000 4.160 4.190 0.72    136,430 4.686 4.602 -1.83 4.51 4.602 2.00 341,070    5.92 6.033 1.87 REFERÊNCIAS BIBLIOGRÁFICAS Ahn, J. W., Park, T. S. and Sung, H. J., 1997, "Application of a Near-Wall Turbulence Model to the Flows over a Step with Inclined Wall", Int. J. Heat and Fluid Flow, Vol. 18, pp. 209-217. Almeida, O., Mansur, S. S. e Silveira Neto, A., 2000, "Numerical Analysis of the 2D Turbulent Vortex Shedding Flow Around a Square Cylinder", Anais da II Escola Brasileira de Primavera, Transição e Turbulência, ABCM, pp. 422-433, Uberlândia, Brasil. Amtonopoulos-Domis, 1981, "Large-Eddy Simulation of a Passive Scalar in Isotropic Turbulence", J. Fluid Mechanics, Vol. 104, pp. 55-79. Bagshaw, N. M., Beck, S. B. M. and Yates, J. R., 1999, "Identification of Fluid Flow Regimes in Narrow Cracks", Proceedings of Instn. Mech. Engrs., Vol. 214, Part C, pp. 1099-1106. Bartello, P., Métais, O. and Lesieur, M., 1994, "Coherent Structures In Rotating Three-Dimensional Turbulence", J. Fluid Mech., Vol. 273, pp. 1-29. Batchelor, G. K., 1953, "The Theory of Homogeneous Turbulence", Cambridge University Press. Bispo, D. J., Nieckele, A. O. e Braga, S. L., 1996, "Convecção Natural em uma Cavidade Retangular Resfriada na Parede Superior", Anais do VI Congresso Brasileiro de Engenharia e Ciências Térmicas â€" ENCIT / VI LATCYM, pp. 1339-1344, Florianópolis, Brasil. Breuer, M., 1998, "Numerical and Modeling Influences on Large-Eddy Simulations for the Flow Past a Circular Cylinder", Int. J. of Heat and Fluid Flow, Vol. 19, pp. 512-521. Brito, R. F., 1999, "Simulação Numérica da Transferência de Calor e do Escoamento de Fluidos", Dissertação de Mestrado, Escola Federal de Engenharia de Itajubá, Itajubá, Brasil. Champagne, F. H., Friehe, C. A., Larue, J. C. and Wyngaard, J. C., 1977, "Flux Measurements, Flux Estimation Techniques and Fine-Scale Turbulence Measurements in the Unstable Surface Layer over Land", J. Atmos. Sci., Vol. 34, pp. 515-530. Chenoweth, D. and Paolucci, S., 1986, "Natural Convection in an Enclosed Vertical Air Layer with Large Horizontal Temperatures Differences", J. Fluid Mech, Vol. 169, pp. 173-210. Choi, J. M. and Anand, N. K., 1995, "Turbulent Heat Transfer in a Serpentine Channel with a Series of Right-Angle Turns", Int. J. Heat Mass Transfer, Vol. 38, No. 7, pp. 1225-1236. Cholet, J. P. and Lesieur, M., 1982, "Parametrization of Small Scales of Three-Dimensional Isotropic Turbulence Utilizing Spectral Closures", J. Atms. Sci., Vol. 38, pp. 2747-2757. Correa, R. A. y Guzmán, A. M., 2000, "Estudio Computacional del Modelo de Flujo y Transferencia de Calor en Canales de Paredes Paralelas Sinusoidales", Anales del 9º COCIM â€" IV CONAE â€" Congreso Chileno de Ingeniería Mecánica, Congreso Nacional de Energía, Valparaíso, Chile, pp. 1-7. Cortella, G., Manzan, M. and Comini, G., 2001, "CFD Simulation of Refrigerated Display Cabinets", Int. J. of Refrigeration, Vol. 24, pp. 250-260. Das, P. K., Tasnim, S. H., Mahmud, S. and Islam, A. K. M. S., 2003, "Effect of Surface Waviness and Aspect Ratio on Heat Transfer Inside a Wavy Enclosure", Int. J. of Numerical Methods for Heat and Fluid Flow, Vol. 13, nº 8, pp. 1097-1122. David, E., 1993, "Modélisation des Écoulements Compressibles et Hypersoniques: une Approche Instationaire", Ph. D. Thesis, Nat. Polytech. Inst. Grenoble. Deardorff, J. W., 1970, "A Numerical Study of Three-Dimensional Turbulent Channel Flow at Large Reynolds Numbers", J. of Fluid Mech., Vol. 41, Part B, pp. 453-480. Ducros, F., 1995, "Simulations Numériques Directes et des Grandes Échelles de Couches Limites Compressibles", Ph. D. Thesis, Nat. Polytech. Inst. Grenoble. Ducros, F., Comte, P. and Lesieur, M., 1993, "Ropes and Lambda-Vortices in Direct and Large-Eddy Simulations of a High Mach Number Boundary Layer Over a Flat Plate", In Turbulent Shear Flows IX, Kyoto, August, Springer-Verlag, Berlin. Fallon, B., 1996, "Large-Eddy Simulation of Stable-Stratification Effects Upon a Backstep Flow", Ph. D. Thesis, INPG-IMG-LEGI, Grenoble. Figueredo, J. R., Ganzarolli, M. M. e Almeida, P. I. F., 1986, "Convecção Natural em Cavidades Retangulares - Solução Numérica", In: II Congresso Latino-americano de Transferência de Calor e Matéria, São Paulo, pp. 62-73. Findikakis, A. N. and Street, R. L., 1982, "Mathematical Description of Turbulent Flows", Journal of Hydraulics Division, ASCE, Vol. 108, Nº HY8, paper 17265, pp. 887-903. Germano, M., Piomelli, U., Moin, P. and Cabot, W. H., 1991, "A Dynamic Subgrid-Scale Eddy Viscosity Model", Center for Turbulence Research, Phys. Fluids A, Vol. 3(7), pp. 1760-3128. Heisenberg, W., 1948, "On the Theory of Statical and Isotropic Turbulence", Proc. Roy. Soc., Vol. A195, pp. 402-406. Kim, J. J., 1978, "Investigation of Separation and Reattachment of Turbulent Shear Layer: Flow Over a Backward Facing Step", Ph.D. Thesis, Stanford University. Kogaki, T., Kobayashi, T. and Taniguchi, N., 1997, "Large-Eddy Simulation of Flow Around a Rectangular Cylinder", Fluid Dynamics Research, Vol. 20, pp. 11-24. Kolmogorov, A. N., 1941, "The Local Structure of Turbulence in Incompressible Viscous Fluid for Very Large Reynolds Numbers", Dokl. Akad. Nauk SSSR, Vol. 30, pp. 301-305. Lankhorst, A. M., 1991, "Laminar and Turbulent Natural Convection in Cavities - Numerical Modelling and Experimental Validation", Ph.D. Thesis, Technology University of Delft, The Netherlands. Lee, S. and Bienkiewicz, B., 1997, "Large-Eddy Simulation of Wind Effects on Bluff Bodies using the Finite Element Method", J. of Wind Engineering and Industrial Aerodynamics, Vol. 67 and 68, pp. 601-609. Lee, S. and Bienkiewicz, B., 1998, "Finite Element Implementation of Large-Eddy Simulation for Separated Flows", J. of Wind Engineering and Industrial Aerodynamics, Vol. 77 and 78, pp. 603-617. Leonard, A., 1974, "Energy Cascade in Large-Eddy Simulation of Turbulent Flows", Advances in Geophysics, Vol. 18A, pp. 237-248. Lesieur, M. and Métais, O, 1996, "New Trends in Large-Eddy Simulations of Turbulence", Annu. Rev. Fluid Mech., Vol. 28, pp. 45-82. Lesieur, M., 1997, "Turbulence in Fluids", Kluwer Academic Publishers, Dordrecht. Lilly, D. K., 1987, "Lectures Notes on Turbulence", In Lectures Notes on Turbulence, J. Herring and J. M. Williams, Eds. World Scientific, USA. Menon, G. J., 1984, "Convecção Natural no Interior de Coletores Solares Concentradores de Parábolas Compostas", Tese de Doutorado, ITA, São José dos Campos, Brasil. Métais, O. and Lesieur, M., 1991, "Spectral and Large-Eddy Simulations of Isotropic and Stably-Stratified Turbulence", J. Fluid Mech., Vol. 239, pp. 157-194. Metwally, H. M. and Manglik, R. M., 2000, "Numerical Solutions for Periodically - Developed Laminar Flow and Heat Transfer in Sinusoidal Corrugated Plate Channels with Constant Wall Temperature", Proceedings of the 34th National Heat Transfer Conference, Paper No. NHTC2000-12216, ASME, pp. 1-8, Pittsburgh, USA. Nieckele, A. O., Abrunhosa, J. D. M. e Ronzani, E. R., 1996, "Simulação Numérica do Escoamento em Degrau com o Modelo de Turbulência k-ï¥ Renormalizado", Anais do VI ENCIT/VI LATCYM â€" Congresso Brasileiro de Ciências e Engenharia Térmica, Florianópolis, Brasil. Nonino, C. and Comini, G., 1998, "Finite-Element Analysis of Convection Problems in Spatially Periodic Domains", Numerical Heat Transfer, Vol. 34, Part. B, pp. 361-378. Oliveira, M. e Menon, G. J., 2002a, "Simulação de Grandes Escalas Utilizada para Convecção Natural Turbulenta em Cavidades", Anais do IX Congresso Brasileiro de Engenharia e Ciências Térmicas - ENCIT-2002, Anais em cd-rom, pp. 1-11, Caxambu, Brasil. Oliveira, M. e Menon, G. J., 2002b, "Convecção Natural Turbulenta em Cavidades Retangulares", Anais do II Congresso Nacional de Engenharia Mecânica - CONEM -2002, pp. 1-10, João Pessoa, Brasil. Oliveira, M., 2005, "Estudo da Convecção Forçada, Natural e Mista em Escoamentos Laminares e Turbulentos Utilizando o Método de Volumes Finitos", Tese de Doutorado, Universidade Federal de Itajubá, Itajubá, Brasil. Olmstead, J. M. H., 1961, "Advanced Calculus", Prentice - Hall, Englewood Cliffs, N.J. Ozoe, H., Yamamoto, K., Sayama, H. and Churchill, S. W., 1974, "Natural Circulation in an Inclined Rectangular Channel Heated on One Side and Cooled on the Opposing Side", Int. J. Heat Mass Transfer, Vol. 17, pp. 1209-1217. Padilla, E. L. M. e Silveira Neto, A., 2000a, "Simulação Numérica de Grandes Escalas, com Modelagem Dinâmica, Aplicada à Convecção Mista", Anais do VIII Congresso Brasileiro de Ciências e Engenharia Térmica - ENCIT 2000, Porto Alegre, Brasil. Padilla, E. L. M. e Silveira Neto, A., 2000b, "Estudo Comparativo entre Modelagem de Smagorinsky e Modelagem Dinâmica", Anais da II Escola Brasileira de Primavera, Transição e Turbulência â€" ETT 2000, pp. 400-411, Uberlândia, Brasil. Park, T. S. and Sung, H. J., 1995, "A Nonlinear Low-Reynolds-Number k-ï¥ Model for Turbulent Separated and Reattaching Flows", Int. J. Heat Mass Transfer, Vol. 38, pp. 2657-2666. Peng, S. and Davidson, L., 1999, "Computation of Turbulent Buoyant in Enclosures with Low-Reynolds-Number k-ï· Models", Int. J. Heat and Mass Transfer, Vol. 20, pp. 172-184. Peng, S. H. and Davidson, L., 2001, "Large-Eddy Simulation for Turbulent Buoyant Flow in a Confined Cavity", Int. J. Heat and Fluid Flow, Vol. 22, pp. 323-331. Petry, A. P. e Awruch, A. M., 1997, "Simulação de Escoamentos Turbulentos pelo Método de Elementos Finitos através da Simulação de Grandes Vórtices", Anais do ENIEF 97, San Carlos de Bariloche, Argentina. Piomelli, U. and Chasnov, J. R., 1996, "Large-Eddy Simulations: Theory and Applications, Turbulence and Transitional Modelling", Kluwer Academic Publishers, pp. 269-336. Pirani, M. J., Almeida, M. S. V. e Manzanares, N., 1996, "O Método dos Volumes Finitos Aplicados a Escoamentos Turbulentos", Anais do IV Congresso de Engenharia Mecânica Norte Nordeste, CEM-NNE, Recife, Brasil. Pirani, M. J., Manzanares, N., Silveira Neto, A. e Almeida, M. S. V., 2000, "Escoamento Turbulento em Grades de Placas Planas Utilizando o Método dos Volumes Finitos e Simulação de Grandes Escalas", Anais do IV Simpósio Mineiro de Mecânica Computacional â€" SIMMEC 2000, pp. 70-77, Uberlândia, Brasil. Prandtl, L., 1925, "On the Fully Developed Turbulence", J. of Applied Mathematics and Mechanics, Vol. 5, pp. 136-139. Scotti, A. and Meneveau, C., 1993, "Generalized Smagorinsky Model for Anisotropic Grids", Phys. Fluids A, Vol. 5(9), pp. 2306-2308. Selvam, R. P., 1997, "Finite Element Modelling of Flow around a Circular Cylinder using LES", J. of Wind Engineering and Industrial Aerodynamics, Vol. 67 and 68, pp. 129-139. Selvam, R. P., Tarini, M. J. and Larsen, A., 1998, "Computer Modelling of Flow around Bridges using LES and FEM", J. of Wind Engineering and Industrial Aerodynamics, Vol. 77 and 78, pp. 643-651. Segerling, L. J., 1984, "Applied Finite Element Analysis", John Wiley and Sons, Inc., Second Edition, New York. Silveira Neto, A., Grand, D. and Lesieur, M., 1991, "Simulation Numérique Bidimensionalle d'un Écoulement Turbulent Stratifié Derriére une Marche", International Journal of Heat and Mass Transfer, Vol. 34, pp. 1999-2011. Silveira Neto, A., Grand, D., Métais, O. and Lesieur, M., 1993, "A Numerical Investigation of the Coherent Structures of Turbulence Behind a Backward-Facing Step", Int. Journal of Fluids Mechanics, Vol. 256, pp. 1-25. Smagorinsky, J., 1963, "General Circulation Experiments with the Primitive Equations. I. The Basic Experiment", Mon. Weather Rev., Vol. 91, pp. 99-164. Suksangpanomrung, A., Djilali, N. and Moinat, P., 2000, "Large-Eddy Simulation of Separated Flow Over a Bluff Rectangular Plate", Int. J. of Heat and Fluid Flow, Vol. 21, pp. 655-663. Tabarrok, B. and Lin, R. C., 1977, "Finite Element Analysis of Free Convection Flow", Int. J. Heat Transfer, Vol. 20, pp. 945-952. Tian, Y. S. and Karayiannis, T. G., 2000a, "Low Turbulence Natural Convection in an Air Filled Square Cavity Part I: The Thermal and Fluid Flow Fields", Int. J. Heat and Mass Transfer, Vol. 43, pp. 849-866. Tian, Y. S. and Karayiannis, T. G., 2000b, "Low Turbulence Natural Convection in an Air Filled Square Cavity Part II: The Turbulence Quantities", Int. J. Heat and Mass Transfer, Vol. 43, pp. 867-884. Wilkes, J. O. and Churchill, S. W., 1966, "The Finite - Difference Computation in a Rectangular Enclosures", AIChE Journal, Vol. 12, pp. 161-166. Wong, H. H. and G. D. Raithby, 1979, "Improved Finite - Difference Methods Based on a Critical Evaluation of the Approximation Errors", Numerical Heat Transfer, Vol. 2, pp. 139-163. Yang, K.-S., 2000, "Large-Eddy Simulation of Turbulent Flows in Periodically Grooved Channel", J. of Wind Engineering and Industrial Aerodynamics, Vol. 84, pp. 47-64. Zhang, W. and Chen, Q., 2000, "Large-Eddy Simulation of Indoor Airflow with a Filtered Dynamic Subgrid Scale Model", Int. J. of Heat and Mass Transfer, Vol. 43, pp. 3219-3231. Zienkiewicz, O. C., 1971, "The Finite Element Method in Engineering Science", McGraw - Hill, London. |
Problem with assigned inlet velocity profile as a boundary condition | Ozgur_ | FLUENT | 5 | August 25, 2015 05:58 |
inlet and outlet boundary condition for turbomachinery solution | siamak1424 | OpenFOAM | 2 | August 15, 2009 12:14 |
Inlet boundary condition | jkwan | FLUENT | 1 | August 5, 2008 22:22 |
Please help with flow around car modelling! | Tudor Miron | CFX | 17 | March 19, 2004 20:23 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 06:13 |
