help for multiphase modeling
Old   July 29, 2008, 05:02
Default help for multiphase modeling
Lan
Hi everyone! I am going to perform a multiphase flow with work medium CO2, CH4, CO, N2 and wet steam considering wet steam condensation using CFX 11.0. I create a fixed composition mixture with CO2, CH4, CO, N2. And then import the iawps library work steam3v, steam3l and steam3vl. but during the multiphase setup process, in the "fluid pairs" index, a default mass transfer model is setup between the fixed compostion mixture and steam3l.
However, there is no mass transfer between the composition mixture and the steam3l.
How I can deal with the problem?
Thank you in advance.
Regards, Lan
Old   August 12, 2010, 06:37
Default wet steam model
maryam
salam is on a distinguished road
hello,
i try to model the real gas that contains water vapor and another components that condensation of water vapor is occurred.
i want to use wet steam model and use srk eos as the udf.
please aware me if i can. and why not.
thanks a lot
salam is offline   Reply With Quote
Old   October 7, 2010, 15:16
sugumaran
sugumaran is on a distinguished road
Originally Posted by salam View Post
hello,
thanks a lot
hi salam....
i m also working on realgas which is partly condensed air.this case includes both vapor and liquid phase. i wrote my udf for single phase. can u help me for two phase of same....
thanks
sugumaran is offline   Reply With Quote
May Focus Area: Turbulence Modeling Jonas Larsson CFD-Wiki 0 May 2, 2006 12:48
Modeling Flow/Saturation/Absorption in Fibers Gene Dougherty Main CFD Forum 0 June 6, 2003 15:49
Solid Modeling Chris Main CFD Forum 10 July 2, 2002 08:12
CFD Modeling of Two-phase Flow in Small Dia.Tubes Eric Poindexter Main CFD Forum 2 September 22, 2000 10:21
Extrusion Modeling Elliot Schwartz Main CFD Forum 1 September 11, 1998 20:08
