DNS for backward-facing step using CFX
Old   July 25, 2008, 11:58
Default DNS for backward-facing step using CFX
Sungho Yoon
I love to do DNS for my backward-facing step.
Even though CFX does not include DNS, it seems to me a way to conduct DNS is to impose Cs = 0.0 for Smagorinsky model.
I wonder wheter any one tried this. Also if you can see any possible problems in doing so, please let me know.
Thank you in advance.
Old   July 25, 2008, 12:48
Default Re: DNS for backward-facing step using CFX
brunoc
Well, I might be wrong here, but to do DNS wouldn't you just need to use a very fine grid and timestep to capture the smallest scales? That would mean no turbulence model (i.e., laminar).
Old   July 25, 2008, 18:09
Rogerio Fernandes Brito
It depends on the Reynolds number too.
Old   July 27, 2008, 11:14
Sungho Yoon
If you do laminar flow calculation, you can't process turbulent properties such as Reynolds stress in CFX.
Old   July 28, 2008, 03:02
If you want to try DNS in CFX you will want to use the laminar turbulence model. The RANS and LES turbulence include simplifications to the stress vector which are normally not important but for DNS you may well need them to get the dissipation right. I hope the flow is a very low Reynolds number. Good luck, you will need it.
Old   July 28, 2008, 05:15
Sungho Yoon
Thank you.
Old   July 28, 2008, 08:15
And an element high number!
Old   July 29, 2008, 18:13
underGroundMan
Have you worked out how fine your grid would have to be? You will have to resolve all the scales in your flow. Therefore you need to calculate the length of kolmogorov scales in your flow. How many processors do you have to run your problem?
Regards
Old   July 29, 2008, 21:07
I used LES in two dimension flow, with sub-grid scale structure function, using the FORTRAN language. I had the 7.2 point of recirculation.
Old   July 30, 2008, 23:12
Did you say you ran a 2D LES simulation? You can't run LES 2D, it is 3D only.
Regards, Glenn Horrocks
Old   August 4, 2008, 06:32
Default Re: COARSE DNS
  #11
Sungho Yoon
What I wanted to try was not real DNS but coarse DNS.
I think I have a proper mesh for three-dimensional LES with yplus =1 approximately. I just wanted to turn off subgrid modelling without refining grid further. I hope this may result in between a proper DNS and and a LES with standard smagorinsky model.
Regards, Sungho
Transient simulation not converging skabilan OpenFOAM Running, Solving & CFD 14 December 17, 2019 00:12
Backward facing step; x/H; U/U0; diemsionless analysis; paraview idrama OpenFOAM 1 December 3, 2013 18:10
Backward facing step. Fluids Main CFD Forum 7 December 4, 2012 12:28
Rearward facing step simulations siw FLUENT 1 September 23, 2009 03:21
Backward FAcing Step - Frequency CFDtoy Main CFD Forum 8 October 29, 2006 21:51
