Design Modeller.
Old   July 21, 2008, 12:34
Default Design Modeller.
MAB
QUESTION 1...I have a circular device sitting inside a rectangular domain(tank). i am trying to build the device and then cut it from the recangular domain... is there anyother way of making the device inside this recangular domain.??? Question 2 ... the divice is fully submerged in water. Now the initial volume fraction of water (and air) is defferent from the outside wave tank(recangular domain) actually some air is trapped in the device. Could you please suggest any idea ot intruducing these two different initialization for volume fractions.
Old   July 21, 2008, 23:23
Default Re: Design Modeller.
Question 1 is a simple question on geometry creation. Do the tutorials on geometry creation and you should be OK.
Question 2 - You have to specify the volume fraction at all points in the domain using a function somehow. This function can either be using CEL expressions (eg step, domain etc) or an interpolation function.
Old   July 22, 2008, 05:19
MAB
Hi Glenn.. thanks for your time. But this is what i already know. My questions are adressing the next step...
Old   July 22, 2008, 20:49
brunoc
You could create a subdomain for the circular region and then use the inside() function of CFX (check your documentation on that) multiplying other functions to prescribe the initial volume fraction field.
It could be something like this: inside()@CircularDomain * VF_CircDomain + (1-inside()@CircularDomain) * VF_RectDomain
Design modeller ease to use taw CFX 4 May 2, 2011 16:51
[Other] Import autocad into Design modeller lcea ANSYS Meshing & Geometry 1 December 1, 2010 14:15
Import autocad into Design modeller lcea CFX 0 November 30, 2010 05:13
CFX design modeller Mirco CFX 2 April 5, 2007 15:05
Info: Short Course On Thermal Design of Electronic Equipment Arnold Free Main CFD Forum 0 August 10, 1999 11:18
