Hi,ereryone.
I'm doing the CFX11.0 tutorial 9 with visual studio 2003 and intel fortran compiler 9.0, and I met the fellowing errors: ------------------------------------------------------------ F:\CFX_test>cfx5mkext PipeValve_inlet.F C:\Program Files\Intel\Compiler\Fortran\9.0\IA32\Bin\ifort -iface:cvf -MD -fpp - include:"C:\Program Files\ANSYS Inc\v110\CFX\include" -object:winnt\\PipeValve_i nlet.o -c PipeValve_inlet.F Intel(R) Fortran Compiler for 32-bit applications, Version 9.0 Build 20050912 Z Package ID: W_FC_C_9.0.024 Copyright (C) 1985-2005 Intel Corporation. All rights reserved. PipeValve_inlet.F(1) : Error: Syntax error, found POUND_BASE '' when expecting o ne of: <LABEL> <END-OF-STATEMENT> ; BLOCK BLOCKDATA PROGRAM TYPE COMPLEX BYTE CH ARACTER ... #include "cfx5ext.h" -------^ PipeValve_inlet.F(1) : Severe: Could not recover from previous syntax error #include "cfx5ext.h" -------^ compilation aborted for PipeValve_inlet.F (code 1) An error has occurred in cfx5mkext: C:\Program Files\Intel\Compiler\Fortran\9.0\IA32\Bin\ifort exited with return code 1. ------------------------------------------------------------ Can anyone help me. Thanks a lot. regards Lan |
Hi everyone!
I met that error because there were some spaces ' 'before the #include "cfx5ext.h" . but now I met another error: ------------------------------------------------- F:\CFX_test>cfx5mkext PipeValve_inlet.F C:\Program Files\Intel\Compiler\Fortran\9.0\IA32\Bin\ifort -iface:cvf -MD -fpp - include:"C:\Program Files\ANSYS Inc\v110\CFX\include" -object:winnt\\PipeValve_i nlet.o -c PipeValve_inlet.F Intel(R) Fortran Compiler for 32-bit applications, Version 9.0 Build 20050912 Z Package ID: W_FC_C_9.0.024 Copyright (C) 1985-2005 Intel Corporation. All rights reserved. C:\Program Files\Intel\Compiler\Fortran\9.0\IA32\Bin\ifort -threads -dll -exe:.\ winnt\\PipeValve_inlet.dll winnt\\PipeValve_inlet.o C:\Program Files\ANSYS Inc\v 110\CFX\lib\winnt\solver-pvm.lib Intel(R) Fortran Compiler for 32-bit applications, Version 9.0 Build 20050912 Z Package ID: W_FC_C_9.0.024 Copyright (C) 1985-2005 Intel Corporation. All rights reserved. ifort: Command line warning: unrecognized source type 'winnt\\PipeValve_inlet.o' ; object file assumed An error has occurred in cfx5mkext: C:\Program Files\Intel\Compiler\Fortran\9.0\IA32\Bin\ifort could not be started, or exited with return code 255: . ----------------------------------------------- regards Lan |
Compile calcMassFlowC | aurore | OpenFOAM Programming & Development | 13 | March 23, 2018 07:43 |
CGNS Compiling | Diego | Main CFD Forum | 17 | December 21, 2014 01:40 |
ParaView for OF-1.6-ext | Chrisi1984 | OpenFOAM Installation | 0 | December 31, 2010 06:42 |
[Netgen] Installation of Netgen in SuSE Linux 92 | edvardsenpriv | OpenFOAM Meshing & Mesh Conversion | 23 | January 16, 2009 06:12 |
error while compiling the USER Sub routine | CFD user | CFX | 3 | November 25, 2002 15:16 |
