July 10, 2008, 13:12 |
ANSYS CFX 12.0
Dear Everybody..
What about ANSYS CFX Version 12.0 when will it be releasing? regards CFDUSERIN |
July 10, 2008, 22:36 |
Re: ANSYS CFX 12.0
I believe before the end of the year. Glenn Horrocks |
July 11, 2008, 21:28 |
Re: ANSYS CFX 12.0
does Anyone know about the new features and capacities of new version? Will we alvbe to make a 2D simulation for student purposes, eg?
July 12, 2008, 06:12 |
Re: ANSYS CFX 12.0
I'm pretty sure that 2D simulations will still be done by creating a 1 element thick 3D simulation. Since CFX is a 3d code, it would take an entire rewrite of the code to make it 2d as well.
July 12, 2008, 12:07 |
Re: ANSYS CFX 12.0
I donīt think so! īcause, when u have a quase-2D simulation (or 3D simulation), we have a different formulation of conservation equations comparing to a real 2D formulation. When u work with vorticity-stream formulation, instead of primitive variables, working with 2D simulation, u have different equations for vorticity, eg...
July 12, 2008, 12:08 |
Re: ANSYS CFX 12.0
u said: "...I'm pretty sure that 2D simulations will still be done by creating a 1 element thick 3D simulation. Since CFX is a 3d code, it would take an entire rewrite of the code to make it 2d as well. ..."
Iīve already known about it, but thanks for your contribution |
July 12, 2008, 12:13 |
Re: ANSYS CFX 12.0
maybe ansys inc. could add more schemes for diffusive terms, and not only use a linear scheme and also add a possibility to put more points of integration when u use a kind of element, for example, hexahedrical element. I wanted to compare the results in modifying this schemes for diffusive terms when iīm studying my heat conducting problems (without fluid flow, as air or water, eg).
July 13, 2008, 19:35 |
Re: ANSYS CFX 12.0
No chance.
You do have the choice of a few diffusion interpolating schemes. But high order elements - no chance. The list of stuff which is coming with CFX V12 is on the CFX-Community website so no need to speculate. Glenn Horrocks |
July 14, 2008, 03:29 |
Re: ANSYS CFX 12.0
#9 |
Glenn,
Whereabouts is the list in the website? Are you talking about the Customer Portal, as I cannot find it. Thanks. |
July 14, 2008, 20:30 |
Re: ANSYS CFX 12.0
#10 |
I can't seem to find it now. Can't remember where it is - ask your support person. Glenn Horrocks |
July 18, 2008, 06:31 |
Re: ANSYS CFX 12.0
#11 |
My last information is, that it will be beginning of next near.
July 30, 2008, 22:19 |
Re: ANSYS CFX 12.0
#12 |
Sorry, no 2D like you are expecting.
September 3, 2009, 07:21 |
Cfx 12.0
#13 |
ravi
Rep Power: 17 |
Does anyone have CFX 12.0 help file. So that I could do the analysis of the gear pump...
Or any online resource... |
September 4, 2009, 04:59 |
#14 |
Rep Power: 17 |
Ansys CFX v12 is yet available. I found a document about what is new in this version: http://cfd.enginsoft.it/software/cfx/ansys-cfx-12.0.pdf |
September 4, 2009, 08:59 |
#15 |
Rep Power: 144 |
Have you tried talking to your CFX support person?
Solidification in Ansys CFX (12.0 ) | mauricio | CFX | 2 | August 11, 2015 10:06 |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 07:27 |
Ansys mesh and CFX | anna | CFX | 3 | August 28, 2006 07:55 |
"ANSYS CFX" and "CFX TascFlow" | ROOZBEH | CFX | 2 | December 13, 2005 02:37 |
CFX bought by Ansys - good or bad?! | Pete | CFX | 38 | February 21, 2003 08:34 |
