Single phase result file for multiphase simulation
Old   July 8, 2008, 14:28
Default Single phase result file for multiphase simulation
Kushagra
Hi there, I have completed one single phase simulation. Now I want to add solid particles also (Eulerian-Eulerian). Will it be ok to use the converged results from single phase simulation as the initial condition for multiphase simulation? Because the single phase result file does not have any solid particle information at all.
I am asking this question because FLUENT manual does not recommend doing it. I want to learn from your CFX eperience.
Thanks very much, Best Regards, Kushagra
Old   July 8, 2008, 19:21
Default Re: Single phase result file for multiphase simula
This sounds like a good starting point to me, particularly if the particle load is light and therefore does not change the fluid flow much.
Old   July 8, 2008, 22:14
Kushagra
Thanks Glenn. I will try it. Kushagra
pisoFoam compiling error with OF 1.7.1 on MAC OSX Greg Givogue OpenFOAM Programming & Development 3 March 4, 2011 18:18
paraview installation woes vex OpenFOAM Installation 15 January 30, 2011 08:11
two Phase column simulation chemeng OpenFOAM 3 August 18, 2010 13:53
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
ParaView Compilation jakaranda OpenFOAM Installation 3 October 27, 2008 12:46
