Visualize mixing (postprocessing)
Old   July 8, 2008, 11:46
Default Visualize mixing (postprocessing)
Terje
I want to model a micromixer where a "red" and a "blue" fluid are mixed. They both have water properties and start from the same inlet and I want to see how the interface between them evolves in a channel (disregarding diffusion).
This can be done by adding another variable which obeys the transportation equations. But when doing so there is quite a bit of numerical diffusion of the interface and the solver spends a lot of time. If, however, I run a simulation with just one phase the solution is quick. Since I have the streamlines these can be tracked back to the inlet to determine which phase is where.
Does anyone know a way to do this in postprocessing?
Thanks for your help!
- Terje
Old   July 8, 2008, 13:10
Default Re: Visualize mixing (postprocessing)
hjli6
Hi, Your case is one phase, it is two materials. You have to select Water volume Fraction for Variable in the postprocessing, the colour map can be selected as White to Blue. I did three kinds water flows. please see: http://e.simwe.com/attachments/2008/...2040520321.gif http://e.simwe.com/attachments/2008/...2040516521.gif
Old   July 9, 2008, 05:21
Terje
Thanks for your suggestion. I do not have access to the links you provided but I would very much like to see them. Could you change the access rights.
I am not sure if I understand your method. Does it involve having the volume fraction variable included in the simulation or is it only postprocessing.
Thanks again!
- Terje
Old   July 9, 2008, 10:42
hjli6
The volume fraction variable is only select in postprocessing.
you may see this link:
http://e.simwe.com/10450/viewspace-7178
Old   July 9, 2008, 13:40
Terje
Nice videos! But I still do not understand how to track the volume fraction in post.
Could you please tell me in some detail what I need to do to e.g. to make a contour plot at the outlet of the volume fraction. Where the volume fraction is given at the inlet and the simulation is only one material.
Thanks!
- Terje
mixing plane model: too much backflow and does not converge sbhi FLUENT 1 December 4, 2014 01:31
Problem with Mixing plane Mitpostdoc FLUENT 0 July 26, 2011 15:31
Meshing a Mixing Plane using ICEM Will Anderson FLUENT 0 November 6, 2010 18:08
What kind of postprocessing should I choose to display the mixing in fluent mixsim? xiqiu FLUENT 0 October 21, 2009 03:42
Mixing plane geometry definition Hbet FLUENT 0 January 18, 2002 08:16
