spanwiperiodic boundary condition for LES
Old   July 4, 2008, 11:44
Default spanwiperiodic boundary condition for LES
Sungho Yoon
I'm doing LES for a backward-facing step. I want to impose periodic boundary condition in spanwise direction (on both side walls). However, it seems I can't apply periodic boundary condition.
I can apply wall condition or symmetric condition. But I don't think it is a good boundary condition for LES.
Would anyone help me?
Thanks in advance.
Sungho
Old   July 4, 2008, 14:43
Default Re: spanwiperiodic boundary condition for LES
cfdIsMad
Why is this not a good BC for LES?
I think its very good BC, it will reduce your computation time. And people often use periodic BC for side walls. If you look through literature you will find for channel flows periodic BC is almost always used for side walls. Can you please explain why you think its not a good idea.
Old   July 4, 2008, 14:46
cfdIsMad
Can you please let me know if you are using any paper to validate your results? Thank you
Old   July 6, 2008, 08:33
Sungho Yoon
I want to apply periodic boundary condition and I believe it is a good boundary condition.
What I meant was I can't find periodic boundary condition in CFX for backward-facing step. (I can use only symmetry, wall, etc...)
I'm trying to validate my data with the following two papers.
1. Direct numerical simulation of turbulent flow over a backward-facing step, JFM, 1997, vol 330, pp 349-374 - HUNG LE a1 , PARVIZ MOIN a1 and JOHN KIM
2. Backward-facing step measurement at low Reynolds number, Re h= 5000 S Jovic, DM Driver - NASA Technical Memorandum, 1994 - ntrs.nasa.gov
Old   July 6, 2008, 23:49
Make sure your mesh faces match on both sides of the periodic interface so you can use a 1to1 interface. Otherwise you have to use a GGI and that is not recommended, especially for LES applications.
Old   July 8, 2008, 07:21
Sungho Yoon
Thank you! I got it.
Sungho Yoon
Domain Imbalance HMR CFX 5 October 10, 2016 06:57
Can anyone give me some hint on how to make traction free boundary condition? poplar OpenFOAM 3 January 14, 2015 03:37
Setting outlet Pressure boundary condition using CAFFA code Mukund Pondkule Main CFD Forum 0 March 16, 2011 04:23
How exactly the "pressure outlet" bdry condition compute properties on the boundary? yating9901 FLUENT 3 June 28, 2010 13:26
How to set boundary condition in Fluent for the fo Peiyong FLUENT 1 November 10, 2006 12:44
