July 3, 2008, 16:13 |
Boundary Conditions 2D foil
I have created a 2D mesh of a foil in a rectangular domain by means of a 2D planar block extruded one cell normal. I tried creating mesh subsets for inlets etc. but in CFX-Pre the only regions I can apply boundary conditions to are generic 2D regions or such. Is there a way in ICEM to specify regions for inlet, outlet walls etc.?
Thanks! |
July 3, 2008, 18:20 |
Re: Boundary Conditions 2D foil
Yes, you can do that in ICEM. You define them as parts, not mesh subsets. Glenn Horrocks |
July 4, 2008, 08:14 |
ok great thanks will try. But do I define the geometry (lines) as the parts or the faces of the elements?
Thanks |
July 6, 2008, 22:48 |
When you mesh the mesh on a face will inheret the part name of the underlying surface. Giving lines and/or points part names will not be seen in CFX-Pre as CFX does not use line or point elements. Glenn Horrocks |
July 26, 2008, 08:09 |
Use Extrude Mesh tool in icem cfd, with 10 layers and 0.1 mm each layer, to make your 3D mesh!
Impinging Jet Boundary Conditions | Anindya | Main CFD Forum | 25 | February 27, 2016 12:58 |
Boundary conditions for 2D Navie-Stockes simulation | L1011 | OpenFOAM | 5 | December 13, 2012 08:17 |
[Netgen] boundary conditions and mesh exporting | vaina74 | OpenFOAM Meshing & Mesh Conversion | 2 | May 27, 2010 09:38 |
Concentric tube heat exchanger (Air-Water) | Young | CFX | 5 | October 6, 2008 23:17 |
A problem about setting boundary conditions | lyang | Main CFD Forum | 0 | September 19, 1999 18:29 |
