Drag Coefficient Verification around Cylinder |
August 23, 2011, 00:18 |
#41 |
Joshua Counsil
Rep Power: 18 |
Please give more of the setup details, e.g., Reynolds number, turbulence model (if any), etc.
#42 |
ST
Rep Power: 16 |
Hi Glenn,
Yes, I am checking it now with 1000 time-steps/cycle. I have previously used 100 and 200 time-steps/cycle. My model is 2d with an added one-element thickness in z-direction. Axially, it covers a distance of 3c (from inlet to object) to 8c (from object to outlet). Laterally, 7c to upper and lower boundary. The total element now is around 200,000. I will increase it further. Cheers, bbhv |
August 23, 2011, 02:55 |
#43 |
Joshua Counsil
Rep Power: 18 |
Sounds like your domain might be too small. 3c from the inlet is pretty small, especially considering the high-pressure front surface that blunt object causes.
Try increasing your domain in every direction and creating a coarse mesh in the extended regions so that the simulation is not significantly longer. |
May 11, 2015, 10:49 |
#44 | |
Emre G
Rep Power: 15 |
I have the same problem. I get Cd=0.5 but exp value is 1.2 for 2D cylinder. What should i do? thanks |
May 11, 2015, 19:27 |
#45 |
Rep Power: 144 |
drag coefficient of cylinder | Avijit | FLUENT | 12 | April 23, 2017 04:26 |
Incorrect Drag and Drag Coefficient for flow over a cylinder | ozzythewise | Main CFD Forum | 8 | June 13, 2012 07:24 |
Coefficient DRAG and LIFT - Cylinder 3D | Jwolf | CFX | 11 | February 4, 2010 06:08 |
Solver and geometry choose for drag coefficient calculation around circular cylinder at large Re | lin | OpenFOAM Running, Solving & CFD | 3 | April 16, 2009 11:50 |
Automotive test case | vinz | OpenFOAM Running, Solving & CFD | 98 | October 27, 2008 09:43 |
