June 25, 2008, 00:40 |
Momentum Source Value
Hi all, could any body help me defining the momentum source value for my problem. i understand that
Momentum Source X Component = -C*(u-uspec) how could i come out with the value for "C" my domain is a compressor blade i did a calculation as follows Momentum source = -c*m(v2-V1) where C - 10e5 m - mass flow rate V2 - exit velocity from the blade V1 - inlet velocity to the blade will it work if not how should i specify to get the right velocity and pr raise across the blade |
[swak4Foam] swak4foam building problem | GGerber | OpenFOAM Community Contributions | 54 | April 24, 2015 16:02 |
Simulation of Axial Fan Flow using A Momentum Source Subdomain | Liam | CFX | 28 | July 16, 2013 08:24 |
pisoFoam compiling error with OF 1.7.1 on MAC OSX | Greg Givogue | OpenFOAM Programming & Development | 3 | March 4, 2011 17:18 |
DxFoam reader update | hjasak | OpenFOAM Post-Processing | 69 | April 24, 2008 01:24 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
