June 24, 2008, 15:12 |
USER_GETVAR for MUSIG variables
Hi, all
I tried to call some variables such as Group I Diameter, Size Fraction, and Index by using USER_GETVAR function. and I keep getting errors to call them. I used the following information: Materials: Water and Air at 25 C Musig Fluid: Air Groups: Group 1 and Group 2 The followings are the <variable_description> that I used: Air.Group 1.Size Fraction Air at 25 C.Group 1.Size Fraction Air at 25 C.Air.Group 1.Size Fraction Air at 25 C.Musig Fluid Air.Group 1.Size Fraction Air at 25 C.Musig Fluid.Air.Group 1.Size Fraction Air at 25 C.Musig Fluid 1.Group 1.Size Fraction I used many different ones, but none of them worked. Do you know the right format for USER_GETVAR? |
February 13, 2017, 12:29 |
Lakshay Garg
Rep Power: 9 |
Were you able to solve your problem Jo? I am facing the same problem
February 13, 2017, 15:52 |
Rep Power: 33 |
You can try the following syntax
For variables independent of the size group MyPolydispersedFluid.<Variable of Interest> For variables dependent of the size group MyPolydispersedFluid.MySizeGroup.<Variable of Interest> Please let us know if it works for you. |
February 14, 2017, 07:38 |
#4 | |
Lakshay Garg
Rep Power: 9 |
Do you know about the format of predefined variables "Group I & J mass, number, etc". As per the "variables" text file, these variables can be used in MUSIG simulation but again the format is a problem. Thank you in advance for your help. |
ADDITIONAL VARIABLES LIMITERS | N.P | CFX | 5 | December 1, 2011 08:47 |
$FOAM_USER_APPBIN & LIBBIN variables not set | rassilon | OpenFOAM Installation | 2 | February 16, 2010 21:54 |
PHI file structure | Eugene | Phoenics | 9 | November 2, 2001 23:00 |
How Do You Name Variables in Difference Equations? | Zi-Wei Chiou | Main CFD Forum | 3 | October 18, 2001 00:47 |
Saving variables on a user patch with physical coordinates | Zoltan Turzo | CFX | 2 | April 20, 2000 16:05 |
