Lift calculation
Old   June 23, 2008, 05:19
Default Lift calculation
icem-noob
Hi Guys
I'm sticking to a problem, concerning the lift calculation of my CFX results.
The results I have is the static pressure on the upper and lower surface of the airfoil,the question is how to calculate the resulting force on that airfoil.
I've displayed the pressure plot on the 2 surfaces and exported it to excel and inserted the "trendline". then I integrated that curve so I got my resulting force. the problem is, that I don't rely on the "excel-way-of-calculation".
Is there another way to compute the force on my airfoil. I don't want to use the "force" data of my results, because I think they aren't right.
thx
Old   June 23, 2008, 07:37
Default Re: Lift calculation
Johnny
You should use the CEL expression for force:
force_y()@surface
Bu if you don't believe the force from CFX, the static pressure alone is not enough to calculate the lift force. You would also need to export face areas and components of the surface normals in order to calculate the force in a specific direction properly.
Lift and drag calculation Franny CFX 16 November 27, 2019 14:47
What is the Basic Calculation of Lift Coef In Modelling 2D?? teguhtf FLUENT 0 October 14, 2009 05:52
Calculation of lift and drag coefficients Prachi CFX 3 August 14, 2007 15:05
lift and drag calculation actone CFX 0 December 27, 2006 18:11
Warning 097- AB Siemens 6 November 15, 2004 05:41
