June 21, 2008, 16:15 |
domain interface on CFX 11
I am exactly obliged to use this type of interface? That is, I always have to create a domain of the type interface when I have a fluid and a solid or when I have a solid with the other solid?
¿Me obligan exactamente a utilizar este tipo de interfaz? ¿Es decir, tengo que crear siempre un dominio del tipo interfaz cuando tengo un flúido y un sólido o cuando tengo un sólido con el otro sólido? |
June 22, 2008, 18:41 |
Re: domain interface on CFX 11
Fluid to solid - yes, need an interface. Solid to solid - if you have defined different materials to the solids then yes you need an interface. Glenn Horrocks |
Can CFX do CHT simulations with a solid domain rotating in a stationary fluid domain? | acro | CFX | 15 | September 23, 2016 11:16 |
Expression with time function | kestasposkus | CFX | 28 | July 24, 2011 06:47 |
CFX domain comparison | Kiat110616 | CFX | 4 | April 3, 2011 22:43 |
Proper output of angle of attack in CFX post | Kevin | CFX | 3 | October 18, 2006 12:18 |
Fluid-2 domain interface | harry | CFX | 0 | November 6, 2004 06:01 |
