outlet boundary condition
Old   June 18, 2008, 10:30
Default outlet boundary condition
Nina Schiepel
I have to carry out a steady simulation with CFX.
I defined a outlet boundary condition at the outlet. The flow is assumed to be subersonic there.
But during the calculation I found out that the flow at the outlet is in some steps supersonic and in other steps subersonic.
I want to konw whether I should swith the boundary condition from the current subersonic outlet boundary condition to the supersonic outlet boundary condition or not.
How are I deal with this problem properly?
Thanks.
Old   June 20, 2008, 21:15
Default Re: outlet boundary condition
cfd.newbie
Hi nina
What are you modelling. What is your mach number? If your mach number is in the range of supersonic flow, only then you should switch your outlet BC to supersonic.
Regards
Old   July 12, 2008, 16:27
AAMIR RIZWAN Deptt. of MATHEMATICS UET LAHORE
i requested that please send the definition of outlet boundary and zero normal gradient condition.
Outlet Pressure-flow coupled boundary condition (Windkessel) cfdfsi Fluent UDF and Scheme Programming 3 July 21, 2017 13:30
Boundary Condition outlet natantyt FLUENT 0 September 27, 2010 16:30
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
inlet and outlet boundary condition for turbomachinery solution siamak1424 OpenFOAM 2 August 15, 2009 12:14
Outlet boundary condition CN FLUENT 6 May 22, 2005 10:37
