Static Pressure Calculation for Mass Flow Rate
Old   June 16, 2008, 05:52
Default Static Pressure Calculation for Mass Flow Rate
Amit Roghs
Dear all,
How is the static pressure at inlet calculated when Mass flowrate is given at inlet condition.
Total Pressure is the sum of Velocity Head & Static Pressure.
Velocity head will be calculated from the value of massflowrate.
But how will be the static pressure calculated?
Thanks for the responses!!!
Amit
Old   June 16, 2008, 22:51
Default Re: Static Pressure Calculation for Mass Flow Rate
Static pressure is extrapolated from the adjacent cells. This is discussed in the manual (but not clearly stated, I grant you).
basic fluid flow problem - is there a way to switch pressure to a flow rate in analyt vlnikolic Main CFD Forum 3 September 16, 2016 05:07
Compressible flow, no data at the outlet mireis FLUENT 6 September 3, 2015 03:10
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 07:27
Maintaining Static Pressure at Fluid Flow Inlet cdevalve FLUENT 3 January 14, 2012 01:11
static pressure from mass flow rate SAM FLUENT 5 October 22, 2004 10:37
