Conjugate Heat Transfer query
Old   June 9, 2008, 05:09
Default Conjugate Heat Transfer query
siw
I'm wanting to know the temperature soak performance of a solid body which is surrounded by a fluid.
If I use the Conjugate Heat Transfer feature in CFX will that tell me anything about the temperature in the solid body - I would expect it does not and I'd need to use the Fluid-Structure Interaction.
Is CHT just about using a solid as a source or sink for heat energy whereby only the behaviour of the fluid is to be understood?
Thanks.
Old   June 9, 2008, 09:03
Default Re: Conjugate Heat Transfer query
Mehul
If you want to observe the shrinkage of solid body due to thermal shock , then it is not possible in CFX. Other wise You can always obtain temerature profiles on solid fluid interections.
Heat Flux at wall in a conjugate heat transfer problem Chander CFX 2 July 9, 2011 23:22
Conjugate Heat Transfer in rhoPisoTwinParcelFoam jabecker OpenFOAM 0 June 23, 2011 10:19
Convective / Conductive Heat Transfer in Hypersonic flows enigma Main CFD Forum 2 November 1, 2009 23:53
Conjugate heat transfer problem hvem10 FLUENT 2 October 29, 2009 18:31
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
