Error detected by routine POKER
Old   Yesterday, 11:41
Unhappy Error detected by routine POKER
Guocq
Guocq is on a distinguished road
When I am doing a transient simulation, I want to change the pressure condition at the outlet in real time. To achieve this function, I created an expression and hope to change the value of the expression at the end of each time step through Junction Box Routine. An error occurred during the CFX-Solver calculation process, indicating that the POKED command was used incorrectly. I suspect that the input parameter CDANAM in the POKED command is set incorrectly. I hope someone can explain in detail the specific usage of POKED in my application scenario. How should I enter the required parameters so that the program can run normally?
Guocq is offline   Reply With Quote
Old   Yesterday, 18:48
Why can't you do this using a CEL expression and not use User Fortran at all? That is much simpler and you will get less errors.
If you have to use User Fortran - why aren't you doing this using a User CEL Function? This is the simplest form of User Fortran and you do not need to get involved in the memory management - which is poorly documented and complex. A User CEL Function is much simpler.
In other words, you are doing this the hard way, and there are at least two easier ways of doing it.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
poker cdanam
two different gas! Fluid pair model! saha2122 CFX 7 February 9, 2022 08:15
How to make user routine just be called once in one time step? doublestrong CFX 3 October 22, 2018 00:06
calculate particle temperature gradient with user routine amd18 CFX 1 April 3, 2017 12:32
user subroutine error CFDUSER CFX 2 December 9, 2006 07:31
user defined function cfduser CFX 0 April 29, 2006 11:58
