June 4, 2008, 00:40 |
About Pitching-Plunging Motion in CFX-Pre
Is there any way to define pitching - plunging motion of an airfoil without using mesh deformation ?
Thanks in advance. Farid |
June 19, 2008, 01:21 |
Re: About Pitching-Plunging Motion in CFX-Pre
Actually, I'm also trying to do this. I currently have a rotating domain inside a stationary domain, and am specifying the motion of the rotating domain using a sin function to alternate between a +ve and a -ve angular velocity, thereby making the rotating domain change direction periodically. This has however been giving me odd results. It seems that the solver works well up until the direction of pitching changes. When it does, the velocity vectors in the rotating domain change drastically. I know, a picture is worth a thousand words. I have a video of it, but can't upload it here I guess. Any help would be appreciated.
Thanks Andy |
June 19, 2008, 13:08 |
Hi Andy, Thanks a lot. I have done a simulation for pitching motion and the results seem reasonable.I used Transient Rotor Stator Option for the Domain interface.
Now I am trying to run a plunging case. But for this case, the motion is translational in both upward and downward. There is a way to do this modeling using mesh deformation. But I want to do it without mesh deformation. Thanks Farid |
June 19, 2008, 13:23 |
Try doing a search for how people do modelling of 'oscillating cylinders in crossflow' (similar motion to your plunging motion. You may find information there on how to do it without using mesh deformation)
I was wondering, did you use a rotating domain with the airfoil inside a stationary domain for the pitching motion you did? Any other specific settings you used? I'm guessing you didn't use mesh deformation for that case? Send me an email: andy.fiedler@gmail.com Cheers, Andy |
Pitching moment at the quarter chord in CFX | k.vimalakanthan | CFX | 5 | April 10, 2016 07:38 |
Defining a domain in CFX Pre | ashtonJ | CFX | 1 | June 13, 2011 03:34 |
Problems with adding two meshes together in CFX Pre | peterputer1 | CFX | 2 | September 23, 2009 09:08 |
CFX - Pre and Workbench License issues | CFX user | CFX | 2 | August 12, 2009 17:59 |
how to giv vibrating motion to a plane wall in CFX | Ramanand Vetrui | CFX | 1 | February 22, 2004 17:48 |
