Using different turbulence models for each domain in CFX |
Yesterday, 07:01 |
Rep Power: 3 |
Hi.
How is it possible to use different turbulence models for each domain? (eg Shear Stress Transport for one part and k-ε for the other. I have tried disabling constant domain physics form options but, it gives me errors about interfaces or some quantities related to turbulence models: Code:
+--------------------------------------------------------------------+ | ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | Equation subsystem: "Wall Scale" has not been found on both sides | | of interface "P1 to P2". Check that you have set consistent phys- | | ics across all domains that use this interface. | | | | | | | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | Stopped in routine DEF_ALGM_SUBSYS_ZIF Or using other packages like OpenFOAM? Kind Regards. |
Yesterday, 07:27 |
Gert-Jan
Rep Power: 28 |
I know it should be possible. I used it in a system with 3 different domains. I had 1) a laminar gas domain, 2) a turbulent water channel, and 3) a metal conducting solid in between. Here the 2 fluid volumes are physically separated.
Is this also the case in your geometry? |
Yesterday, 09:26 |
#3 | |
Rep Power: 3 |
No, it is just water that goes through different domains. Fluid domains are not separated by solid parts. |
Yesterday, 09:36 |
Gert-Jan
Rep Power: 28 |
Then I expect it is not possible.
Main question is: Why would you like to do this? Any reason to not use SST all over? I never use k-e. I only deviate from SST when the application requires this. Then I end up at to RSM, DES, LES, etc. |
Yesterday, 11:55 |
#5 | |
Rep Power: 3 |
I wanted to explore the possibility and effects of using multiple turbulence models. I don't intend to use the k-epsilon model specifically; I'm just mentioning it as an example. |
Yesterday, 12:42 |
#6 | |
Rep Power: 33 |
Do you understand the differences between the two models? Based on those initial differences, you may be able to predict if the simulation will be worth doing. My 2c
cfx, domain, turbulence, zone |
Turbulence postprocessing | Mohsin | FLUENT | 2 | October 3, 2016 15:18 |
Pressure distribution on a wall | darazsbence | CFX | 17 | October 6, 2015 11:38 |
Floating point exception: Zero divide | liladhar | CFX | 11 | December 16, 2013 05:07 |
CFX domain comparison | Kiat110616 | CFX | 4 | April 3, 2011 23:43 |
Discussion: Reason of Turbulence!! | Wen Long | Main CFD Forum | 3 | May 15, 2009 10:52 |
