cfx solver error
Old   June 3, 2008, 00:36
Default cfx solver error
sandhesh
my problem is iam trying to solve a multiple domain heat exchanger ,ie fluid-solid -fluid interface problem.
i changed in cfx pre the "NOCONSTANTPHYSICS" variable value to 1, such that i could create multiple fluid domain in cfx pre,with two different fluid properties.
but while solving in solver it shows me Error in subroutine "FNDVAR" : Error finding variable DENSITY_FL2 GETVAR originally called by subroutine GET_MFLOIP_ZIF .
What to do for this,if there is any way to overcome this error,iam using ansys cfx 10
Old   June 3, 2008, 07:57
Default Re: cfx solver error
Mehul
It seems that one of the material you have defined have not been incorporated with density. Because the value of density is need during conjugate heat transfer analysis.
Old   June 3, 2008, 09:09
sandhesh
yes iam sure i specified density for all fluids separately,but iam facing that error in solver,
if any one solved such type of multiple fluid domain problem in cfx 10 without error
Old   June 6, 2008, 11:13
lee
i exactlly have the same problem for 2 doamins, 1 is single phase and the other is 2-phase ...
compile errors of boundary condition "expDirectionMixed" liying02ts OpenFOAM Bugs 2 February 1, 2010 21:11
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 11:23
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 03:32
attach/detach (valve opening/closing) phsieh2005 OpenFOAM Running, Solving & CFD 2 March 21, 2009 06:18
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
