Non-overlap setting for transient-rotor interface |
Today, 06:02 |
#21 |
Karl G
Rep Power: 2 |
Ok, it has also worked with the geometry initially described at the start of this thread. The mesh is pretty rough so it is not very sharp but well. Easy to fix.
So i guess my problem is solved :-) Thanks for the help guys! |
boundaries condition, interface domains, non-overlapping, rotation |
Fluent Parallelization Problem After AC Power Dropped | pawl | Hardware | 5 | November 13, 2016 07:08 |
using chemkin | JMDag2004 | OpenFOAM Pre-Processing | 2 | March 8, 2016 23:38 |
[snappyHexMesh] determining displacement for added points | CFDnewbie147 | OpenFOAM Meshing & Mesh Conversion | 1 | October 22, 2013 10:53 |
Cells with t below lower limit | Purushothama | Siemens | 2 | May 31, 2010 22:58 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 05:41 |
