Is it possible to monitor residuals...
Old   May 26, 2008, 23:02
Default Is it possible to monitor residuals...
Tim
Hi All,
Is it possible to monitor residuals of specific areas in a region while a solution is being run? Or is it only possible to monitor the residuals of entire regions?
Thanks, Tim.
Old   May 27, 2008, 00:48
Default Re: Is it possible to monitor residuals...
R.Y
Tim,
Residuals of different domains can be ploted in the monitor respectively. You can select "Monitor Properties" from the right-click menu on the monitor screen, and then toggle on or off variable residuals you want. Maybe you need to define the specific area as a domain. But I am not sure because I have not found the way to display arbitrary areas' residuals.
May this help.
R.Y
