ICEM CFD Mesh Quality "Volume change"
Old   May 23, 2008, 15:43
Default ICEM CFD Mesh Quality "Volume change"
Paul Brainerd
Hi, one of the mesh quality criteria is "Volume change" in ICEM. a value of <2 indicates acceptable value especially when we are using mesh deformation in CFX. I have a problem, i use hex meshing scheme, at a particular adjacent surface, "volume change" value is >2, how do i rectify this problem.
Thanks in Advance for your help. Paul
Old   May 26, 2008, 00:37
Default Re: ICEM CFD Mesh Quality "Volume change"
R.J
i think changing mesh size of 2 or 3 dimensions will be the solution. it is the same as the expansion ratio that less than 2 is preferred.
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 09:54
[ICEM] Unstructure Meshing Around Imported Plot3D Structured Mesh ICEM kawamatt2 ANSYS Meshing & Geometry 17 December 20, 2011 12:45
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 22:11
[ICEM] trouble with mesh quality from ICEM in CFX Solver escher25 ANSYS Meshing & Geometry 0 February 28, 2011 08:38
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
