EDM constants A and B
Old   May 23, 2008, 04:22
Default EDM constants A and B
Radha Raman Das
I am modeling for Hydrogen combustion by using the standard Eddy dissipation model. When I used the default values of 4 and -1 for A and B respectively, the maximum flame temperature is 2900 K. To match the experimental data (from a paper that I was referring to) of max temp of 1600 K, I found that A and B should take values of 0.5 and -1.0 respectively. My doubt is whether such a low value of 0.5 for A is acceptable? Is there any lower limit on the value of A as such?Is such a value theoretically valid?
Regards,
Radha Raman das.
Model constants in EDM Jürgen FLUENT 1 November 9, 2017 03:54
How are the integration constants for the JANAFthermo class derived? tomf OpenFOAM Running, Solving & CFD 2 May 15, 2015 08:47
model constants in standard k-epsilon model Yogini Main CFD Forum 0 January 14, 2010 11:33
what constants to choose for std k-e model daniel.struwig FLUENT 0 April 18, 2009 07:51
Modelling a turbulent jet and k-epsilon constants Ant Siemens 3 January 24, 2005 16:56
