Wall temperature contours in CFD Post of CFX results |
November 12, 2024, 02:59 |
Muhammmad Waris
Rep Power: 2 |
Hi! I have done multiphase simulation using RPI wall boiling model in CFX. Now I want to visualize the contours of wall temperature. There is no such variable in CFD Post. There are seperate variables for liquid and vapor wall temperature and I am not sure which one to read. I have also performed the same simulation using FLUENT and there was a variable of TEMPERATURE in those simulation results. Kindly help in this regard.
November 12, 2024, 04:31 |
Rep Power: 144 |
What boundary condition did you use for the wall? Or did you model the wall as a solid with conjugate heat transfer (CHT)?
(Note I am not very familiar with the RPI boiling model)
November 13, 2024, 00:06 |
Muhammmad Waris
Rep Power: 2 |
I have given heat flux at that particular wall on which i want wall temperature
November 13, 2024, 10:58 |
Erik
Rep Power: 23 |
I don't think "Wall Temperature" is ever a variable. Temperature should be the wall temperature if you are using "hybrid" values in the plot. "Conservative" would be the temperature of the first node adjacent to the wall.
I don't know if RPI makes any difference, maybe it does, I'm not 100% sure as it's been a while since I've used RPI, and I used a solid wall in my RPI model so didn't need to check. |
November 14, 2024, 03:31 |
#5 | |
Muhammmad Waris
Rep Power: 2 |
November 19, 2024, 09:50 |
Erik
Rep Power: 23 |
I see.
You may have to either model the actual wall, or perhaps it is possible to form an expression for "WallTemp" using the various wall heat transfer coefficients and wall adjacent temperatures? This is possible in single phase flow, where "WallTemp" = (Wall Heat Flux / Wall Heat Transfer Coefficient) + Temperature. This Method is listed in the FAQs: https://www.cfd-online.com/Wiki/Ansy...ficient_in_CFX Of course, if it is even possible, it may be more difficult with your two-phase model, and you may have to use various applicable Heat Fluxes, adjacent temperatures, and HTCs, and perhaps even sum the Delta T's? Likely much easier to just model a thin wall. |
cfd post, cfx, multiphase flow, rpi wall boiling model |
[openSmoke] libOpenSMOKE | Tobi | OpenFOAM Community Contributions | 562 | January 25, 2023 10:21 |
Stream Function Contours in CFD Post | KathrynM | FLUENT | 0 | February 21, 2021 15:29 |
Expert Parameters in CFX-pre | ebrahem | FLUENT | 0 | December 20, 2019 03:39 |
Same results for different ambient temperature in ANSYS CFX | jinuvarghese | CFX | 4 | July 19, 2018 01:46 |
Problem with an old Simulation | FrankW | CFX | 3 | February 8, 2016 05:28 |
