ICEM 11 MESH
Old   May 20, 2008, 02:14
Default ICEM 11 MESH
CC
Hi All,
I want to mesh a simple 2D rectangular block with a semi circle indentation on the top edge. I read in ICEM tutorials that a blocking is required when meshing, is this the only method? Is ICEM capable of creating nodes on the edges and compute meshes from the nodes (similar to FLUENT)? If so, where can I find some info on this?
THANKS! CC
Old   May 20, 2008, 05:48
Default Re: ICEM 11 MESH
Dr. toner
hi cc,
you can mesh your 2D part automatically with tetras, sure, but in your case i would recomment a structured mesh.
i guess it depends on what you want... the blocking is time-consuming but delievers better results in a 2D case (just my opinion)
just use "volume meshing" under "global mesh setup" if you want to use the unstructured mesh.
Old   May 20, 2008, 13:32
Rogerio Fernandes Brito
anyway, any mesh you use, you will have good results! hexa is better because you waste less time of simulation, but with tetra mesh, you must refine the mesh very well and your time of cpu might be up to 10 times more (it depends on your case, of course).
Old   May 20, 2008, 20:30
CC
I need the mesh to be structured (Hexa). Does that mean I have to use "Blocking" or are there other ways (nodes?) of doing so?
Thanks, CC.
Old   May 20, 2008, 21:46
Try using hexa mesh without blocks! u will not have a control of refinement of mesh, but, itīs easier to create it!
Old   May 27, 2008, 09:34
Felix
CC, I don't know if it is possible to create and Hexa-mesh without blocks but blocking usually works well.
You can associate the blocks' edges to the physical edges and then specify the number of nodes and their distribution on these. Extra blocks/edges inside the geometry will only improve your control on what's going on.
Felix
Gambit problems Althea FLUENT 22 January 4, 2017 04:19
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 07:42
ICEM Edit Mesh blackbody ANSYS Meshing & Geometry 3 March 8, 2010 03:49
Boddy fitted Hexcore Mesh in ICEM Cfd Mitch CFX 0 December 29, 2008 07:07
ICEM clustering of mesh points and multiple edges webhaw CFX 4 July 25, 2007 17:29
