ICEM 11 mesher
Old   May 19, 2008, 11:11
Default ICEM 11 mesher
DAK565656
Suppose we have some kind of geometry. For sumplicity let it be a right angle. After generating simple tetrahedral mesh using ICEM 11 we can discover that tetrahedrons that lie near this angle don't fit to it - tetrahedrons are so big and coarse that they can't duplicate the form of right angle. The question is how to fix it?
Old   May 19, 2008, 11:31
Default Re: ICEM 11 mesher
icem-noob
click on the "right angle"-spline(s) -> set spline-mesh options to a appropriate low mesh size -> mesh curve -> mesh all ... voila
that was a problem I had to handle with too...
Old   May 21, 2008, 11:11
DAK565656
Sorry but I misunderstand something. Do you propose to set curve mesh options using "Mesh -> Curve Mesh Setup"? Should I set finer sizes until mesh fits good to "right angle"? I can't really understand what does "Mesh -> Mesh Curve" do. And one more thing: the "right angle" is formed by two surfaces and there are no curves, so I can't setup anything concerning curve.
Old   May 23, 2008, 11:07
DAK565656
I think there should be some tools concerning aligning mesh with surfaces in edit mesh tab...
Old   May 27, 2008, 09:46
Felix
Have you tried creating a curve at the intersection? Run the Repair Geometry/build topology tool ( check the filter points and curves options). ICEM always puts nodes on points and curves so this should fix your problem.
Let us know if it worked,
Felix
Old   May 28, 2008, 10:52
DAK565656
That works! Thanx for answer
Old   May 30, 2008, 11:15
DAK565656
Unfortunately, after repairing geometry mesh couldn't be built properly - thousands of mistakes and problems (((
PEM Fuel cell module meshes. ICEM vs workbench aarvay FLUENT 24 March 2, 2020 07:50
[ANSYS Meshing] Workbench 13: Structured Hexa Meshes rooftop ANSYS Meshing & Geometry 19 March 31, 2016 03:33
Design Modeler to ICEM..... Joe CFX 0 January 24, 2008 04:39
ICEM 10 mesh scale foe CFX Korsh Mik CFX 2 October 7, 2005 10:07
ICEM CFD 5.1 Hex-Tet mesh merging failure bogesz CFX 1 January 29, 2005 07:46
