Mass conservation equation for multi-component flow |
September 24, 2024, 06:32 |
Xiangjie Qin
Rep Power: 3 |
This is the mass conservation equation for multi-component flow in CFX. I am wondering if the densities marked in the red box means the same thing? That is, the ratio of the mass of component i to the volume of the mixed fluid.
September 24, 2024, 10:37 |
Erik
Rep Power: 23 |
No, they do not appear to be the same thing, which should be obvious since they are different symbols, but I tried to follow the equations to double check.
The second one looks like just the normal density of component i. I'm happy to be corrected though. |
September 24, 2024, 11:42 |
#3 | |
Rep Power: 33 |
Would you mind pointing out the Release, Documentation Section, and Equation number?
What are the best settings for a channel flow simulation? | Ashkan Kashani | CFX | 3 | October 13, 2022 22:36 |
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 07:40 |
Mass flow rate history over solution step- rhoSimpleFoam | gian93 | OpenFOAM Post-Processing | 0 | December 8, 2019 11:20 |
Pressure Outlet Targeted Mass Flow Rate | LuckyTran | FLUENT | 1 | November 23, 2016 11:40 |
Ansys CFX problem: unexpected very high temperatures in premix laminar combustion | faizan_habib7 | CFX | 4 | February 1, 2016 18:00 |
