Code Error 101
Old   September 23, 2024, 10:02
Default Code Error 101
Mey
MNMK is on a distinguished road
I try to simulate the distribution of combustion products inside and outside my car. When I attempt to calculate the model in transient model, I encounter the following error:
I must mention that I do not have any issues when I calculate in steady-state model.
| Buoyancy Reference Information |
Domain Group: CarInside
Buoyancy has been activated. The absolute pressure will include
hydrostatic pressure contribution, using the following reference
coordinates: ( 2.08440E-03,-3.79753E-01,-8.01360E-01).
| An error has occurred in cfx5solve: |
| The ANSYS CFX solver exited with return code 101. No results |
| file has been created. |
End of solution stage.
| The following user files have been saved in the directory |
| /home/simulation/08qeibl7.ea0/CFX_008: |
| pids, mon |
This run of the ANSYS CFX Solver has finished.
How can I fix this error?
wishes,
MNMK is offline   Reply With Quote
Old   September 23, 2024, 10:11
Opaque will become famous soon enough
May I ask which release you are using?
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Opaque is offline   Reply With Quote
Old   September 23, 2024, 10:13
Default reply
Mey
Workbench Version 2021R2
Old   September 23, 2024, 10:30
Is it possible for you to run on a more recent release?
If you compare the output files between the steady state output file, and the transient one, can you spot non-obvious differences?
With the available information, I can only advise you to contact the Ansys CFX support line.
Old   September 23, 2024, 11:09
Mey
Can you please say to me how can I increas the quality of my mesh? +--------------------------------------------------------------------+
| Topology Simplification |
| ****** Warning ****** |
| Topology simplification is activated with the following |
| restrictions: |
| - Mesh regions referenced only within User Fortran and NOT |
| in the command file will cause the solver to stop. |
| - The solver will stop during any "Edit Run in Progress" step |
| if new 2D regions are referenced. |
| Mesh Statistics |
| Domain Name | Orthog. Angle | Exp. Factor | Aspect Ratio |
| | Minimum [deg] | Maximum | Maximum |
| CarInside | 12.7 ! | 70 ! | 29 OK |
| Surrounding | 13.1 ! | 117 ! | 34 OK |
| Global | 12.7 ! | 117 ! | 34 OK |
| | %! %ok %OK | %! %ok %OK | %! %ok %OK |
| CarInside | <1 7 93 | <1 3 97 | 0 0 100 |
| Surrounding | <1 7 93 | <1 3 97 | 0 0 100 |
| Global | <1 7 93 | <1 3 97 | 0 0 100 |
What exactly is the meaning of an exclamation mark in mesh statistics?
Old   September 23, 2024, 11:57
https://ansyshelp.ansys.com/account/...3sn_mesh_stats
Old   September 24, 2024, 06:24
Mey
Hello again,
I found a solution. Normally, I calculate my model through a cluster, but when I calculated it locally on my computer, I saw more errors related to the initialization of my model. When I fixed them, I could calculate the model in transient without any problem.
whishes
How to make CFD code architechture flexible enough for future modifications? aerosayan Main CFD Forum 6 September 3, 2021 05:35
Fortran->Assembly : How to remove redundant non-vectorized code? aerosayan Main CFD Forum 6 November 20, 2020 06:37
The FOAM Documentation Project - SHUT-DOWN holger_marschall OpenFOAM 242 March 7, 2013 13:30
Small 3-D code Zdravko Stojanovic Main CFD Forum 2 July 19, 2010 11:11
public CFD Code development Heinz Wilkening Main CFD Forum 38 March 5, 1999 12:44
