September 4, 2024, 21:46 |
Countour value extraction
Alex
Rep Power: 2 |
I have modelled a Francis turbine runner on Ansys CFX. The results file provides the ability to plot a pressure contour map over the blade (image 'Pressure').
I am trying to plot the Thoma number which will require using the pressure value at each node (or point) along the blade for a calculation (image 'Desired Contour' shows the desired contour I'm trying to produce, sourced from a provided report.) The expression I intended on using was (Pi-Pv)/(rho*g)*)(1/Hn), where Pi is the pressure value at each point. When I attempt to write this as an expression, I can not obtain the correct function to compute individual pressure values as indicated by the images, and hence am unsure on how to proceed Thankyou for your help, I appreciate it |
September 5, 2024, 04:53 |
Rep Power: 144 |
You appear to be attempting to add it as a CEL expression. This is not the correct approach. You need to add it as a new user variable (not a CEL expression) and define the variable to have the expression you want for the value. The expression should probably be something like (p-1228[Pa])/(998*9.81)*(1/86.6)
September 9, 2024, 08:08 |
#3 | |
Alex
Rep Power: 2 |
Are you able to direct me to the correct user guide as to how to identify different parameters for use in expression/solver computations. I was unable to find the documentation that the 'p' in "(p-1228[Pa])/(998*9.81)" was automatically registered for pressure in any ansys documentation. As always thankyou for your swift replies |
September 9, 2024, 18:41 |
Rep Power: 144 |
The CFX Reference guide has several chapters on CEL, including functions, available variables (such as "p") and how CEL works.
Fluent 3d VOF post-processing/data extraction | Adam Inator | FLUENT | 2 | June 22, 2024 11:35 |
how do i fix installation error of ansys 19.0 on ubuntu 18.04 | rid_taki | ANSYS | 15 | June 7, 2021 06:32 |
[snappyHexMesh] surfaceFeatureExtract error- Feature line extraction? | anu.raghun | OpenFOAM Meshing & Mesh Conversion | 2 | July 2, 2019 10:43 |
2D mesh extraction problem | Caner | STAR-CCM+ | 0 | June 22, 2011 05:33 |
particle extraction | dsmith | CFX | 1 | September 22, 2009 07:10 |
