first wall layer thickness and droplet size
Old   May 2, 2008, 03:01
Default first wall layer thickness and droplet size
itchie
Hi. I want to simulate wall deposition using Lagrangian particle tracking, should the thickness of the first layer from the wall larger than the droplet diameter? Is there any appropriate ratio for that? Thanks guys!
Old   May 13, 2008, 15:42
Default Re: first wall layer thickness and droplet size
Arun
you are doing for particles or spray???
Old   May 13, 2008, 20:08
itchie
Hi, I am simulating fluid particles in continuous vapor. Do you have any idea? Thanks!
Old   May 14, 2008, 10:03
Arun
Hi... To my knowledge there is no appropriate ratio for that. The particles are treated as sources for solving using PSI-cell method. So i think you can mesh according to your y+ and Reynolds number. regards
