Reynolds number CEL expression counter plot CFD post |
August 26, 2024, 14:42 |
Upa
Rep Power: 2 |
Hey,
I have the simulation of a bioreactor. I would like to show the counter plot of the reynolds number distribution across the fluid. I saw that Reynold number is not a variable in CFD post but it can be calculated using a expression. Does anyone know the equivalency of the Re equation for CFD post (CFX) variables names? How can it be calculated in each point of the fluid doamin? Thank you |
August 26, 2024, 15:18 |
Rep Power: 11 |
Reynolds number is calculated for some section of model, not for all points like some scallar field. Reynolds formula use hydraulic diameter and bulk velocity.
If you want to know Re for your calculation you can set variables for density, dynamic viscosity, select some hydraulic diameter typical for your model and calculate average velocity at inlet or other cross section and calculate Re the same way as in handbook but you only get one value for your simulation. |
cel expression, cfd post, reynolds |
use the message in macro DEFINE_PROFILE with parallel processor | alireza_T | Fluent UDF and Scheme Programming | 3 | May 11, 2022 02:08 |
Foam-Extend 4.0 simpleFoam motorbike parallel error? | EternalSeekerX | OpenFOAM Running, Solving & CFD | 0 | May 10, 2021 04:55 |
parallel run OpenFoam | Srinath Reddy | OpenFOAM Running, Solving & CFD | 13 | February 27, 2019 09:15 |
Outlet boundary condition in interFoam | Andrea_85 | OpenFOAM Running, Solving & CFD | 51 | July 20, 2017 13:31 |
SigFpe when running ANY application in parallel | Pj. | OpenFOAM Running, Solving & CFD | 3 | April 23, 2015 14:53 |
