August 27, 2024, 07:27 |
#21 |
Rep Power: 144 |
Then isn't this either:
* A number of separate steady state runs, each at a fixed heat source value covering the range of interest which will give you a temperature versus heat source power curve, OR * A transient model Doing it as a single steady state model with a variable heat source is not good practice as it is not a steady state model the way you have set it up.
August 27, 2024, 08:03 |
#22 |
Mey
Rep Power: 6 |
I do not want to create any curve of temperature vs. heat source. By changing the heat source value, the outlet temperature will change. To estimate this, I do not think the case should be calculated based on time.
Instead of changing a parameter and starting the case, I would prefer to see the effect during the calculation. Is this wrong? The absolute value is not my focus. My aim is to study the trend of changes. |
August 27, 2024, 12:31 |
#23 |
Rep Power: 33 |
How can we probe/evaluate something that has not been computed? I am open to suggestions from YOU.
August 27, 2024, 13:46 |
#24 |
Mey
Rep Power: 6 |
It was my mistake. I calculated the model using a constant heat source and knew the temperature was about 130°C. Therefore, I thought it would be possible, but I realized it is not.
August 27, 2024, 18:25 |
#25 | |
Rep Power: 144 |
Can I write temperature dependent UFD code in ansys fluent expression? | GreyMat | FLUENT | 0 | August 9, 2022 10:53 |
Ansys Fluent Expression ISO Surface not appearing in Location button | ebrahem | Fluent UDF and Scheme Programming | 2 | January 12, 2022 06:43 |
can user define a location dependent density in Define_property udf macro? | Pmaroul | Fluent UDF and Scheme Programming | 2 | January 21, 2019 15:34 |
Evaluating expression at a specific location in CFX Pre | gotang | CFX | 4 | August 17, 2017 10:33 |
Need help to write scripts in User Fortran | Casper_07 | CFD Freelancers | 1 | April 12, 2016 12:59 |
