sinsoudial time varying BC
Old   April 29, 2008, 18:59
Default sinsoudial time varying BC
cfd-student
Hi guys
I am simulating a plane duct flow with time varying total pressure BC at the inlet and outlet is sealed. I have specified an equation at the inlet for this BC.
I am getting a message from solver that "a wall has been placed at the inlet". If I change my inlet BC to opening how would that affect my solution? I am running laminar flow. How else can i resolve the issue? Thank you
Old   April 29, 2008, 19:45
Default Re: sinsoudial time varying BC
Read the documentation about the difference between outlets, inlets and openings. In short inlets and outlets only flow in one direction and place "walls" at the boundary in the case of reverse flow. An opening allows forward or reverse flow.
Old   April 30, 2008, 06:23
cfd-student
Thank you Glenn but how the forward/reverse flow can affect the outcome. Any ideas? What if I use non-reflecting BC at the inlet?
Old   April 30, 2008, 22:48
Rogerio Fernandes Brito
what kind is this problem?? is this a closed cavity? (or a semi-open cavity?)
Old   May 1, 2008, 20:06
cfd-student
semi-open cavity! I am using following expression at the inlet y=A*sin(omega*t). Inlet is opening, outlet is sealed, side walls are symmetry and upper and lower sides are wall. I have randomily chosen amplitude, omega is in radians per second and time is my time step. I am not getting a sine wave the way I should do. What could be wrong?? Thank you for your help Rogerio and others.
cfd-student
Floating point exception error Alan OpenFOAM Running, Solving & CFD 11 July 1, 2021 22:51
time varying boundary condition cfd-student CFX 0 April 15, 2008 09:31
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 15:09
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 19:07
Time Varying BC A.S. Siemens 1 January 31, 2005 07:37
