August 21, 2024, 14:19 |
Multiphase simulation frozen field
Upa
Rep Power: 2 |
Hey,
Is it possible to run a multiphase simulation of a stirred tank (air+water) with a frozen field approach? 1- Run a single-phase sim (water) 2- Usign Expert parameters, only solve for the air using the single-phase results as initial values. If it is, which "solve"options shoud be turned off in Expert paramers? Many thanks |
August 21, 2024, 18:38 |
Rep Power: 144 |
I think it unlikely that approach would converge.
Why is doing this using the normal approach unacceptable? In other words, do a single phase simulation first and use it as an initial condition for a normal multiphase simulation?
August 22, 2024, 05:56 |
Gert-Jan
Rep Power: 28 |
You can turn off fluids and turbulence. Numerically it will converge, but to a solution that's worth nothing since it is completely unphysical. The air bubbles will influence the water flow and vice versa. You cannot ignore this. You're abusing the options the software provides you.
August 22, 2024, 12:33 |
Upa
Rep Power: 2 |
I was suspecting that the frozen approach didn't make sense for a multi-phase sim.
It's just that it's impossible to run a multi-phase simulation even with parallitzation an extremly low time step. Either the Solver exit with code 1 or the simulation time it's extreeeeeeeeeeeeeemly low. Since it is not completely necessary for my Thesis, I will forget about it. Thanks |
August 22, 2024, 13:37 |
#5 | |
Rep Power: 33 |
1 - The physics requires it 2 - The model is extremely complex, and requires physics understanding to simplify it to make it manageable 3 - The setup has something inconsistent, missing, or it is not realistic.
air, expert parameter, multiphase, water |
Scalar field blows up (only) after restarting the simulation | backscatter | OpenFOAM Running, Solving & CFD | 3 | September 16, 2018 06:56 |
Mapping Field Data for Mesh Regions from Another Simulation | veterator | OpenFOAM Pre-Processing | 1 | July 10, 2018 05:28 |
Thermal Simulation using Multiphase VOF model in Fluent | hari.poudyal47@gmail.com | Fluent Multiphase | 0 | July 20, 2015 11:31 |
Simulation multiphase airlift reactor with Eulerian multiphase model question???? | dilok.kumyoo | FLUENT | 0 | January 28, 2015 02:15 |
Need help in Multiphase simulation | leonlo1984 | FLUENT | 0 | January 16, 2011 10:28 |
