Axial Compressor CFD-Help needed
Old   April 29, 2008, 10:06
Default Axial Compressor CFD-Help needed
Pankaj
Dear All,
I have no prior experience of periodic simulations. As Axial Compressors have more than 30 blades in a single rotor plus it requires Guide vanes,Stator means for a 360 deg case it will have more than 100 blades in a single stage.Thus mesh gets too huge.
So one must do periodic simulation.But with different No.of blades in stator,rotor & Guide Vanes can we analyse a single stage using Rotational Periodicty?(since for a frozon rotor interface areas doesnt match)
I am trying it,but solver gets overflow.I m stuck with the situation.Can anybody pull me out of this situation.
Thanks for your precious time.
Old   April 29, 2008, 14:29
Default Re: Axial Compressor CFD-Help needed
Andrew
How many blades are on each component and how do they align?
In order for there to be periodicity, the numbers of all the features around the axis must share a common factor. For instance, if you have 32 blades on your rotor and 7 guide vanes, your geometry won't be periodic regardless of the orientation of the rotor. If any component does not exhibit periodicity, then the geometry as a whole does not.
I understand the frustration as I am currently working with a simulation that would be 1/4 symmetric, except for one feature that exists in only 1 quadrant. As a result I can not use any symmetry on my geometry containing over 3,000 surfaces so my mesh contains over 20,000,000 cells.
axial and z-velocity difference? user0314 FLUENT 1 May 27, 2016 13:30
Axial Compressor experts needed.... arunraj CFX 5 August 17, 2011 20:21
how to plot out circumferentially mass averaged axial velocity in a rotor? wildli FLUENT 0 July 17, 2010 16:54
Model Axial Fan Chien-Chi Chao Siemens 1 February 1, 2001 23:13
About the design of axial fans HanCheolHeui Main CFD Forum 0 September 8, 1998 11:13
