Generating turbogrid compatible .curve files from turbine data |
August 14, 2024, 17:14 |
Noname
I have the information of the sections used in a blade inccluding stsgger angle, cord length and their radius. I need to generate the .curve files based on this data. I don't know if I have to provide the profile curves in planes normal to z axis or I have to wrap them around an imaginary cylinder having the given radius.
I would also appreciate documentations about the requirements of such curves. |
August 18, 2024, 07:37 |
Daniel
Rep Power: 9 |
The user Manuel documentation of Turbogrid should show you the. Curve setup.
You basically have 3 files representing the Hub, shroud profile and the blade profiles. Within the blade.Curve you can have as many profiles as you need along your blade span. The coordinates can be XYZ or cylindrical data. There should be example cases of such files in the ansys install directory. Have a look there. There is also a turbine case. |
cfx, tidal turbine, turbogrid |
[Commercial meshers] Problem with Mesh conversion from FLUENT Meshing to OpenFOAM | mn17jyf | OpenFOAM Meshing & Mesh Conversion | 3 | November 1, 2023 09:49 |
export solver output data files to .txt | pattim | OpenFOAM Post-Processing | 0 | October 27, 2022 15:34 |
[OpenFOAM] How to get the coordinates of velocity data at all cells and at all times | vidyadhar | ParaView | 9 | May 20, 2020 20:06 |
UDF value to large for defined data type | Anna73 | Fluent UDF and Scheme Programming | 9 | September 30, 2018 22:18 |
Writing Case and Data Files Using Journal/Scheme Files | svp | Fluent UDF and Scheme Programming | 0 | April 5, 2011 11:04 |
