why the solver reject it? Anyone with experience?
Old   April 25, 2008, 21:20
Default why the solver reject it? Anyone with experience?
bearcat
I ran a very simple CFX application. But the solver could not work anyway. I am sure the licence is 100% okay. I first thought perhaps I used multi-block in the domain in my CGNS mesh. Then I try a Fluent mesh. It should be a single domain without internal interface this time. But the problem still appear. I have absolutely no idea about this trouble. Anything wrong with my setup or mesh?
Thank you.
The following is the solver messagesorry it might be a little bit long)
+--------------------------------------------------------------------+ | | | CFX Command Language for Run | | | +--------------------------------------------------------------------+
LIBRARY:
MATERIAL: Air Ideal Gas
Material Description = Air Ideal Gas (constant Cp)
Material Group = Air Data,Calorically Perfect Ideal Gases
Option = Pure Substance
Thermodynamic State = Gas
PROPERTIES:
Option = General Material
ABSORPTION COEFFICIENT:
Absorption Coefficient = 0.01 [m^-1]
Option = Value
END
DYNAMIC VISCOSITY:
Dynamic Viscosity = 1.831E-05 [kg m^-1 s^-1]
Option = Value
END
EQUATION OF STATE:
Molar Mass = 28.96 [kg kmol^-1]
Option = Ideal Gas
END
REFERENCE STATE:
Option = Specified Point
Reference Pressure = 1 [atm]
Reference Specific Enthalpy = 0. [J/kg]
Reference Specific Entropy = 0. [J/kg/K]
Reference Temperature = 25 [C]
END
REFRACTIVE INDEX:
Option = Value
Refractive Index = 1.0 [m m^-1]
END
SCATTERING COEFFICIENT:
Option = Value
Scattering Coefficient = 0.0 [m^-1]
END
SPECIFIC HEAT CAPACITY:
Option = Value
Specific Heat Capacity = 1.0044E+03 [J kg^-1 K^-1]
Specific Heat Type = Constant Pressure
END
THERMAL CONDUCTIVITY:
Option = Value
Thermal Conductivity = 2.61E-2 [W m^-1 K^-1]
END
END
END END FLOW:
SOLUTION UNITS:
Angle Units = [rad]
Length Units = [m]
Mass Units = [kg]
Solid Angle Units = [sr]
Temperature Units = [K]
Time Units = [s]
END
SIMULATION TYPE:
Option = Steady State
EXTERNAL SOLVER COUPLING:
Option = None
END
END
DOMAIN: Default Domain Modified
Coord Frame = Coord 0
Domain Type = Fluid
Fluids List = Air Ideal Gas
Location = fluid
BOUNDARY: Default Domain Modified Default
Boundary Type = WALL
Location = wall 4
BOUNDARY CONDITIONS:
HEAT TRANSFER:
Option = Adiabatic
END
WALL INFLUENCE ON FLOW:
Option = No Slip
END
WALL ROUGHNESS:
Option = Smooth Wall
END
END
END
BOUNDARY: inlet
Boundary Type = INLET
Location = pressure inlet 6
FLOW REGIME:
Option = Supersonic
END
HEAT TRANSFER:
Option = Static Temperature
Static Temperature = 132.56 [K]
END
MASS AND MOMENTUM:
Normal Speed = 568 [m s^-1]
Option = Normal Speed and Pressure
Relative Static Pressure = 10700 [Pa]
END
TURBULENCE:
Option = Low Intensity and Eddy Viscosity Ratio
END
END
END
BOUNDARY: outlet
Boundary Type = OUTLET
Location = pressure outlet 5
FLOW REGIME:
Option = Supersonic
END
END
END
BOUNDARY: plenum_outlet
Location = pressure outlet plenum
FLOW REGIME:
Option = Subsonic
END
MASS AND MOMENTUM:
Option = Average Static Pressure
Relative Pressure = 2741 [Pa]
END
PRESSURE AVERAGING:
Option = Average Over Whole Outlet
END
END
END
DOMAIN MODELS:
BUOYANCY MODEL:
Option = Non Buoyant
END
DOMAIN MOTION:
Option = Stationary
END
MESH DEFORMATION:
Option = None
END
REFERENCE PRESSURE:
Reference Pressure = 0 [atm]
END
END
FLUID MODELS:
COMBUSTION MODEL:
Option = None
END
HEAT TRANSFER MODEL:
Option = Total Energy
END
THERMAL RADIATION MODEL:
Option = None
END
TURBULENCE MODEL:
Option = k epsilon
END
TURBULENT WALL FUNCTIONS:
Option = Scalable
END
END
END
OUTPUT CONTROL:
RESULTS:
File Compression Level = Default
Option = Standard
END
END
SOLVER CONTROL:
ADVECTION SCHEME:
Option = Upwind
END
CONVERGENCE CONTROL:
Length Scale Option = Conservative
Maximum Number of Iterations = 50
Timescale Control = Auto Timescale
Timescale Factor = 1.0
END
CONVERGENCE CRITERIA:
Residual Target = 1.E-4
Residual Type = RMS
END
DYNAMIC MODEL CONTROL:
Global Dynamic Model Control = On
END
END END COMMAND FILE:
Version = 11.0
Results Version = 11.0 END EXECUTION CONTROL:
INTERPOLATOR STEP CONTROL:
Runtime Priority = Standard
EXECUTABLE SELECTION:
Double Precision = Off
END
MEMORY CONTROL:
Memory Allocation Factor = 1.0
END
END
PARALLEL HOST LIBRARY:
HOST DEFINITION: host6170215
Remote Host Name = 617-0215
Host Architecture String = intel_xeon64.sse2_winnt5.1
Installation Root = C:\Program Files\ANSYS Inc\v%v\CFX
END
END
PARTITIONER STEP CONTROL:
Multidomain Option = Independent Partitioning
Use Large Problem Partitioner = Off
END
MEMORY CONTROL:
END
PARTITIONING TYPE:
MeTiS Type = k-way
Option = MeTiS
Partition Size Rule = Automatic
END
END
RUN DEFINITION:
Definition File = C:/Team/cfx_fluent_bleed.def
Interpolate Initial Values = Off
Run Mode = Full
END
SOLVER STEP CONTROL:
END
MEMORY CONTROL:
END
PARALLEL ENVIRONMENT:
Number of Processes = 1
Start Method = Serial
END
END END
+--------------------------------------------------------------------+ | | | Solver | | | +--------------------------------------------------------------------+
+--------------------------------------------------------------------+ | | | ANSYS CFX Solver 11.0 | | | | Version 2007.01.15-19.20 Mon Jan 15 19:24:21 GMTST 2007 | | | | Executable Attributes | | | | single-int32-32bit-novc6-optimised-supfort-noprof-nospag-lcomp | | | | Copyright 1996-2007 ANSYS Europe Ltd. | +--------------------------------------------------------------------+
+--------------------------------------------------------------------+ | Job Information | +--------------------------------------------------------------------+
Run mode: serial run
Host computer: 617-0215 Job started: Fri Apr 25 20:04:55 2008 No license for ANSYS CFX Solver (All Models) could be found.
+--------------------------------------------------------------------+ | ERROR #001100247 has occurred in subroutine . | | Message: | | | | The solver is unable to continue because of licensing problems. | | | | A license for the following capability level could not be checked | | out: | | | | Basic Capability Solver | | | | Please carefully examine the error message output above and check | | that: | | | | 1) LM_LICENSE_FILE points to the correct license server | | | | 2) The ".flexlmrc" file points to the correct license server | | | | 3) The required capabililty exists on the license server | | | | 4) The license server is up and running. | | | | These problems can be checked using the ANSYS license manager. For| | further troubleshooting information please consult the section on | | setting up licensing in the ANSYS CFX installation manual. | +--------------------------------------------------------------------+
+--------------------------------------------------------------------+ | An error has occurred in cfx5solve: | | | | The ANSYS CFX solver exited with return code 1. No results file | | has been created. | +--------------------------------------------------------------------+
End of solution stage.
Old   April 27, 2008, 14:39
Default Re: why the solver reject it? Anyone with experien
andy2o
"I am sure the licence is 100% okay."
Sorry, but unfortunately CFX simply does not seem to agree with you! So what makes you sure?
I don't think this has anything to do with your mesh or problem set-up - as a different error message would be given. And it is the basic solver it cannot find a license for...
If CFX crashes during a run, or if there are network or computer problems, sometimes a license is not released correctly at the end of a run. If this happens, when you start the next run the license manager thinks the old run is still going and still using your license. You should run the ANSYS license manager, as the error message advises - I often find the easiest thing is to tell it to "Reread the license file" (but on a multiple user system you have to be careful!).
Regards, andy
Old   April 27, 2008, 15:49
bearcat
Thank you for your advice.
I search this forum and find that I am not the only one encountering "ERROR #001100247". I tested a very simple channel flow case, it's okay. But when I tried some other cases, the problem comes again. I have the experience running a multiblock turbine stator and rotor separately, they are all right. When I combined the two domains together and ran the coupled simulation, the "ERROR #001100247" arose. The domain interface setup is correct to my best knowledge.
If a definition file worked once, it works every time. If it doesn't, it will never work. This is very tricky. I don't have any clue where is wrong. As I use CFX on workstation in the college computer lab, I can't access the license manager.
Thanks.
Old   April 27, 2008, 19:12
andy2o
OK... I was clearly wrong about this one. Apologies! I have been lucky enough never to see this problem myself (all my license errors have indeed been real license errors...). Good luck with sorting this out!
I hope someone else posts more helpful advice than I did!
Best regards, Andy
Old   April 27, 2008, 21:03
The problem is definitely in the licensing. The error message clearly says so.
I think what the problem is that you have a basic capability solver license, and that does not allow many physics such as multiple frames of reference (you use that for turbine simulations), multiphase, radiation and several other advanced physics options. There is also a node-limited solver option which some academic institutions use, you can only run small models on these licenses.
Old   April 28, 2008, 13:47
bearcat
I first did think we lack the full capability solver license when I did the coupled turbine simulation. But I have to give up this idea later when one of my coworker got the same work done in the lab. I got a copy of his .cfx and def. documents, and it really runs! I tried to find out what's the difference between his setup and mine. He used only one block for stator, one block for rotor, and the grid quality is not very good. he can applied multiphase flow model and erosion model in the simulation. So far, I have no hint and no luck stopping this evil error.
Our university obtain the CFX license from the donation agreement with ANSYS Inc. At least the full capacity solver is okay as I know. Whether it sets a limit on the maximum cell number, I never meet such warning message and have to check it out.
Thanks.
Old   April 28, 2008, 15:08
bearcat
I find it out now. There really exists a limit for the maximum number of cells that I can use in the software. I tried about 700k cells, it shows the license problem. when I cut the domain in half, it works this time.
Quarter Burner mesh with periosic condition SamCanuck FLUENT 2 August 31, 2011 12:34
Error message Pandu Sattvika CFX 0 March 1, 2002 16:28
Could you comare StarCD with CFX 5?Help, please... Suteh CFX 54 November 7, 2001 21:12
CFX 5.5 Roued CFX 1 October 2, 2001 17:49
Setting a B.C using UserFortran in 4.3 tokai CFX 10 July 17, 2001 17:25
