Pelton turbine
Old   April 24, 2008, 12:38
Default Pelton turbine
lu
I've some problems with CFD analysis of a Pelton turbine. If I change the geometry, CFX doesn't care and it returns me the same values of force and torque. It happens even if I move the geometry of 15 mm and with meshes fine or coarse. Someone tells me that it's a problem of Ansys CFX, when you work with an incompressible fluid. Help me, Glenn, please!
Old   April 24, 2008, 20:59
Default Re: Pelton turbine
Rogerio Fernandes Brito
Lu, who are you? I intend to study some day Pelton turbines! I would like to know about the geometry parameters involving this kind of turbine! In this type of hydraulic turbine, it has two domains: air and water. Could you give us your experience about this simulation? Where are doing the mesh? Are you making all the simulation or only one part of the domain computational? If you wanna talk about this interesting subject, see below my e-mail and MSN: rogeriofbrito@oi.com.br and MSN: rogeriobrito2007@hotmail.com
Old   October 18, 2011, 04:03
Vishal
vishal.indomitable is on a distinguished road
Send a message via Yahoo to vishal.indomitable
Lu,
I am working on free surface flows. I would like to know the boundary conditions and the other parameters which you would have defined. May be I can help you in this case.
You can share problem to me on my id
vishal.indomitable@gmail.com
vishal.indomitable is offline   Reply With Quote
Problem with torque output from a turbine simulation. pa-dundas FLUENT 5 July 17, 2022 06:27
Flow simulation in a Pelton turbine nozzle fivos FLUENT 0 April 19, 2011 12:46
GMO pelton turbine greatjeans FLOW-3D 3 September 4, 2010 12:54
Simulation of Pelton Turbine: boundary conditions? massimo CFX 0 September 26, 2006 04:56
free surface model of pelton turbine bucket Mark Jones Main CFD Forum 0 April 10, 2000 09:20
