HELP!!: PARALLEL CFX ERROR IN LINUX
Old   April 23, 2008, 10:22
Default HELP!!: PARALLEL CFX ERROR IN LINUX
JP
Hello Im trying to run the cfx in a multicore machine and i get this error message:
Equipo-A:/usr/ansys_inc/v110/CFX/bin # ./cfx5parallel -setup -local 2 libpvm [pid2878] mksocs() connect: No such file or directory libpvm [pid2878] socket address tried: /tmp/pvmtmp014289.0 libpvm [pid2878] mksocs() connect: No such file or directory libpvm [pid2878] socket address tried: /tmp/pvmtmp014289.0 libpvm [pid2878] mksocs() connect: No such file or directory libpvm [pid2878] socket address tried: /tmp/pvmtmp014289.0 libpvm [pid2878] mksocs() connect: No such file or directory libpvm [pid2878] socket address tried: /tmp/pvmtmp014289.0 libpvm [pid2878]: pvm_mytid(): Can't contact local daemon An error has occurred in cfx5parallel:
echo conf | "/usr/ansys_inc/v110/CFX/tools/pvm3.4.4_11-2/lib/pvm" "/usr/ansys_inc/v110/CFX/bin/PVMhosts" exited with return code 1.
Cannot get current PVM configuration: error calling PVM or unknown table format:
pvmd already running.
libpvm [pid2882] mksocs() connect: No such file or directory libpvm [pid2882] socket address tried: /tmp/pvmtmp014289.0 libpvm [pid2882] mksocs() connect: No such file or directory libpvm [pid2882] socket address tried: /tmp/pvmtmp014289.0 libpvm [pid2882] mksocs() connect: No such file or directory libpvm [pid2882] socket address tried: /tmp/pvmtmp014289.0 libpvm [pid2882] mksocs() connect: No such file or directory libpvm [pid2882] socket address tried: /tmp/pvmtmp014289.0 libpvm [pid2882]: pvm_mytid(): Can't contact local daemon An error has occurred in cfx5parallel:
echo add Equipo-A | "/usr/ansys_inc/v110/CFX/tools/pvm3.4.4_11-2/lib/pvm" "/usr/ansys_inc/v110/CFX/bin/PVMhosts" exited with return code 1.
Unable to find host table in output from PVM daemon:
Error adding host Equipo-A.
CAN ANYONE HELP ME PLEASE?
THANKS... JAVIER.
Old   April 23, 2008, 11:06
Default Re: HELP!!: PARALLEL CFX ERROR IN LINUX
Martin
look in your /tmp/ direction. There should be a pvmd.XXXX file. If you delete this file it should work.
Regards
Old   April 23, 2008, 11:23
JP
Thanks Martin:
But i´ve tried that before and didnt get good results.. When I put in my command window:
./cfx5solve -def 1.def -par-local -partition 4
I get no answer ( im not sure but i think is halted)
the message i related before was when i write in the console:
./cfxparallel -setup -local 2
and now i know the error message was a consecuence of the many times i´ve been tring to setup without halting the pvm.
Fininishin i kill all my pvm process and when i try the cfx5solve command i dont get any answer another time.
What its my problem??
Thanks.
Old   April 23, 2008, 11:37
Martin
I never had this problem. Did you try to start this run/another run in serial mode?
Old   April 23, 2008, 11:40
JP
Hi;
Yes, it works on serial mode. The problem comes with the parallel.
Should i do anything special to launch in local parallel?. I´ve just buy my machine and install cfx in a suse 10.3 distribution.
Thanks Javier.
Old   April 23, 2008, 11:57
Martin
Sorry, i have no idea of this. We have an IT department here. I hope someone different can help you ...
Old   April 23, 2008, 12:00
JP
Thanks anyway!
To help i have a HP machine with suse 10.3
Javier.
Old   April 23, 2008, 13:56
longbow
Where did you run your case? "./cfx5solve" indicates that you are running it at CFX installation folder. This may cause the problem.
Old   April 24, 2008, 05:03
JP
Hi and thanks!
I change the launch directory and it seem to improve. But i´m still in problems:
When I launch with cfx5solve -par-local partition 2 ti generates two files in the temp directories with the name PVMD.0 y PVML.0. When i edit the pvml.0 file i see this lines:
[t80040000] 04/24 09:31:34 Equipo-A (0.0.0.0:1077) LINUXX86_64 3.4.4 [t80040000] 04/24 09:31:34 ready Thu Apr 24 09:31:34 2008
[t80040000] 04/24 09:31:34 tm_connect() can't open t-auth file: No such file or directory
I dont know what is the t-auth file.. can anyone help me please.
Thanks Javier.
cfx distributed parallel running problem in linux greatwall CFX 0 August 19, 2011 01:26
Cannot run Star-CCM+ parallel in Linux dburns Siemens 9 April 27, 2010 13:01
parallel processing- linux clusters manoj s FLUENT 2 June 20, 2007 19:48
problem with linux parallel James FLUENT 2 December 11, 2006 03:39
Parallel Fluent on Linux clusters Chengwang Lei FLUENT 3 November 24, 2004 03:05
