July 23, 2024, 11:05 |
The dimensionless grid spacings
chunlong Tan
Rep Power: 4 |
Dear all,
I want to know how to solve Xplus, Yplus and Zplus in CFX-post. Thank you. |
July 23, 2024, 18:37 |
Rep Power: 144 |
Using your chosen expression for X+, Y+, Z+ define a variable with those expressions in CFD-Post.
Note that Y+ probably already exists as a solution variable if you are doing a turbulent simulation - but read the documentation about it to make sure it is using the definition you want.
July 23, 2024, 21:19 |
chunlong Tan
Rep Power: 4 |
In these expressions, the height of the first layer grid on the wall needs to be used, but I don't know how to reference this variable
July 23, 2024, 21:51 |
Rep Power: 144 |
The variable is called "Wall Distance" and will be produced when you use a turbulence model which requires it - that is SST and its related models. Wall distance is not required for turbulence models like k-e so it is not available with those models.
July 23, 2024, 23:11 |
chunlong Tan
Rep Power: 4 |
Thank you very much for your reply.
I found this "Wall Distance" in my CFX-POST. But how do I get Δx,Δy,Δz? |
July 23, 2024, 23:14 |
Rep Power: 144 |
What is your definition of Dx, Dy and Dz?
July 23, 2024, 23:49 |
chunlong Tan
Rep Power: 4 |
I am currently using large eddy simulation for aerodynamic analysis of compressor blades.
The relevant reference suggests paying attention to the x+,y+ and z+. According to relevant references, Δx, Δy, and Δz are the grid spacing of the spanwise, pitchwise, and streamwise in the cascade passage, respectively. (In my opinion, they are the grid spacing of three different directions) |
July 23, 2024, 23:55 |
Rep Power: 144 |
There is no easy way of getting these parameters as there is no easy way of defining the span, pitch and streamwise directions. If your geometry is aligned to the coordinate axes it is straight forward, but in general there is no easy way to get this.
In the past when I did that sort of work I estimated it manually by looking at the mesh and measuring the distance between nodes in the appropriate directions.
July 24, 2024, 02:48 |
#9 |
chunlong Tan
Rep Power: 4 |
I get it, thank you again.
How to make grid for LES simulation | dinhanh | Main CFD Forum | 3 | November 11, 2015 02:37 |
Generating elliptic grid around NACA SC2-0714 airfoil | DA6righthand | Main CFD Forum | 20 | November 3, 2015 07:50 |
Grid Adaptation | Suresh | FLUENT | 0 | October 15, 2003 13:18 |
GRID TO GRID INTERPOLATION in FLUENT | calogero | FLUENT | 3 | June 4, 2003 08:32 |
Numerical methods for discontinuous grid interfaces? | Hansong Hang | Main CFD Forum | 12 | September 16, 1998 22:26 |
